Question about Epson Stylus CX3200 All-In-One InkJet Printer
Scanner stopped working, any idea how to get it going again, am now on vista if that makes a difference
  • icklej Jan 13, 2009
    i have the drivers installed auto via vista but need to reset the fault somehow but don't know how
  • Anonymous Jan 17, 2009
    Helo
    Pleas hold
    support Draive(3working EPSON STYLUS CX3200)
    on windows vista 64 DOwnload
    Web site EPON
You should be use the native Vista driver which comes with the operating system
Posted on Jan 13, 2009
Need help in troubleshooting scanner problems for HP 7310xi. My scanner doesn't work at all. When I hit the 'scan to' button, the display reads "You need to install or run HP software for this...
Take the program completely out and restart computer. Install it again and install completely with out leaving any software programs out. You do have cd? If not go to hp.com and click on support for drivers and download them again. Make sure you have correct operating system checked. 32 bit is different than 64 bit....xp/vista..etc
Jan 03, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Canoscan N656U Scanner Driver would not work on Vista
This will work:
1) Download the drivers for XP from Canon's website
2) Install the drivers.
3) They will install to C:/Temp/CanoScanCSUv571a, go there
4) There is a compressed file called: CanoScanCSUv571a.exe in the foler
5) Use 7-zip to uncompress the folder
6) Plug in your scanner
7) Go to your device manager under the Control Panel
8) Go to Imaging Devices and select your scanner
9) Right click to update driver information
10) Select browse my computer for driver software
11) Type in: C:\Temp\CanoScanCSUv571a
12) Click next and your scanner will work.
Aug 15, 2009 | Canon CanoScan N650U Flatbed Scanner
Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Aug 07, 2009 | Syscan DocketPORT 465 Scanner
Scanner "not installed"
Try it again after you get Vista Service pack1 installed. My obsoleted HP4200C scanjet started to work again.
Aug 03, 2009 | HP Office Equipment & Supplies
Cipherlab 1160 bar code scanner
open the scanner and check for solders dry joints, then re-solder.
check the cable connector maybe it is not snap right.
shaking device to make it work usually mean something loose in solder or cable connections.
Apr 01, 2008 | Computers & Internet
Canon Scanner - Twain Pilot
QUICK ANSWER: use the original USB cable that came with the scanner.
LONG EXPLANATION:
Using Vista (32 bit version) and a Canon N670U scanner with the new drivers installed from the CanonUSA website. This driver is works for Canon scanners: LiDE 20, LiDE 30, N670U, N676U and N1240U, found at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=6625
Canon says it doesn't support Vista 64 bit version. I couldn't get the scanner to work and kept getting the TWAIN error also, despite uninstalling / reinstalling the driver. Finally, decided to disconnect my 3rd party 16 foot USB cable and use the original cable. I swear, it WORKED! I can't explain why, but it did. Perhaps there is increased resistance, hence reduced power going to the scanner by using longer/different USB cable? Anyhow, it worked...go figure. If you have the 64 bit version of Vista, I guess it won't work(?).
Mar 24, 2008 | Canon CanoScan N656U Flatbed Scanner
VISTA Driver
I just called brother and got to the bottom of this problem. When you download the file from their website, it should give you two files.
1. "Data"
2. "Setup420CN"
(my model is different from the 240C but it's the same problem)
Now, open "Setup420CN" folder, then "Usa", then run "Setup"
If you run the Setup application in "Data" folder, then you get the error message over and over again.
So, just run the Setup from the "Setup420CN" folder and you should be good to go!
Dec 15, 2007 | Brother MFC 240C All-In-One InkJet Printer
Benq scanner 5250c driver for vista
Hi alls, this is my solution for Benq Scanner 5250C under Win Vista and Win 7 [both 64bits and Ultimate version]; [sorry for my English Im Spanish]
- Disable signature verification of drivers;
* Start Menu à Run and type this command; bcdedit /set nointegritychecks ON
- Restart the computer.
- Install this driver from Benq homepage; [scanner_sw_5250c_v6.3.zip]
Support page; http://benq.co.ae/support/downloads/downloads.cfm?product=558
Driver to download; ftp://211.78.86.210/scanner/drivers/5250c/scanner_sw_5250c_v6.3.zip
Install it with Administrator privilege [right mouse button …] press yes when ask if you want install unsigned driver.
Run Mirascan driver, it say that not found any scanner, close this application, unplug the USB scanner and plug again the USB cord. Run again Mirascan … and calibration will start and all possibilities are ok.
Remember to enable the signature verification of drivers;
- Run; bcdedit /set nointegritychecks OFF
- Restart the PC.
by JoinMA
bibi.
Nov 11, 2007 | Agfa SnapScan E25 Flatbed Scanner
CanoScan Vs. Windows Vista
Tom, your solution is incorrect. I have just got my Canoscan working fine with Vista, simply using Canon's official XP drivers and unpacking them in XP compatibility mode. Is working fine with just a bit of experimentation. (You need the Canon toolbox software too, all of which is available from canon.com)
Nov 02, 2007 | Canon CanoScan N656U Flatbed Scanner
Epson Stylus CX3200 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
