Question about Sony CDP-CE315 5-Disc CD Changer
Sony CDP-CE315 Disc Changer will not open
Disc tray will not open
SOURCE: sony cdp-cx355 cds skip only on tracks 1 through 5
I got a free one of these from my work...well that is because it was having the same problem and they didn't want to mess with it haha. Sooo...I brought it home..thinking i could just buy a cd cleaner kit and clean the dirty lens..which is what normally causes these problems. To my dismay this didn't work (later found that the lens is a good half inch away from the disc)..so i decided to open the bad boy up (hey I got it for free...no harm crackin it open :-) ) After hitting the lens with a can of air..I tried again...no go. And just so you all know...this player runs vertically..not horizontally. I want to know how does the player read? the lens in stationary. All other players i have seen the lens moves up and down. I'm thinking it might have something to do with that. I gave up on cleaning it and started doing some searches..this was the only forum that was somewhat helpful. I agree with Silverscreen. When i watch the cd's playing the disc wobbles SLIGHTLY up and down. I think the rear stand-alone wheel is a bit too loose. ..The amount it wobbles is hardly noticed but is the only thing i see out of the ordinary.
Posted on Mar 10, 2008
VOTIT
  • 2071 Answers
SOURCE: Sony CDP-C505 door stuck open
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 17, 2008
welcomejee
  • 10594 Answers
SOURCE: Rotary table on Sony CDP-CX225 200 disc changer will not rotate
I think CD Mechanism needs service and might required belts replacement.
You need to get service manual of your CDX-C225 model to do this job as manual contains all technical info about mechanism etc.
Posted on Nov 07, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Posted on Jan 15, 2009
SOURCE: Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Posted on Apr 03, 2009
I have a sony cdp cx355 that seems to have a disc stuck and the door will not open to remove it. How should I proceed?
You have to remove the cabinet to expose the inner workings. Once inside, you should be able to see the stuck CD. Be careful to avoid damaging any parts of the player mechanism as you work the CD back into the carriage. You may find that once the CD is back in place normal operation resumes.
Sep 04, 2016 | Sony MegaStorage CDP-CX355 300-Disc CD...
Disc will not load on sony cdp cx400
Loader mechanism fault. Not engages the CD properly to desired tray section. Contact any service technician. The loader tray should be repaired, and this is not a user repairable fault.
Oct 17, 2014 | Sony CDP-CX400 400-Disc CD Changer
Cdp-ce315 skips in songs
My answer here only concerns if you're trying to play burned audio CDs. Burn your audio CDs at the lowest speed (1). Try the JVC/Taiyo Yuden brand.
Nov 09, 2011 | Sony CDP-CE315 5-Disc CD Changer
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
My dics dor to its changer wont close
open it up
the tray has somthing stuck init
Mar 02, 2010 | Sony CDP-C445 5-Disc CD Changer
My Sony CDP-C305 tray won't open. What should I do?
You will have to replace all belts, this unit all most 20 years old, probably could use some cleaning and re-greasing too.
Nov 01, 2009 | Sony CDP-C305 5-Disc CD Changer
In/out dial on bottom of Sony CDP-C305 ... what does it do?
It is Transit Key to protect optical lens mechanism from shocks while transportation unit. remove it before playing unit.
Aug 06, 2009 | Sony CDP-C305 5-Disc CD Changer
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
Disc not found
most of the times it is the lens, but ou done that already
are you ure that you did it proporly,,try again
else it's a bit serious problem...you need a repair
Please don't forget to rate me "FIXYA"...thank you!
Mar 19, 2009 | Sony CDP-CE315 5-Disc CD Changer
CDP CX300 Disc player door remains open
Look on hifiengine.com for the service manual. I just got one for my Sony CDP-CX235 and there was definitely something about the door mechanism in it. The site is free to join too
May 03, 2008 | Audio Players & Recorders
Sony CDP-CE315 5-Disc CD Changer Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
