Question about Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
I have a delta a112.18.1 hand held shower head that leaks water where the hose connects to the shower head
5 Suggested Answers
  • 13 Answers
SOURCE: no hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
Posted on May 28, 2009
  • 297 Answers
SOURCE: Leak in hand held hose, Delta In2ition
you must be missing a washer or gasket that goes in the hose end, of the hose try teflon tape,this is all your plumber is going to do.
Posted on Jul 17, 2009
  • 102 Answers
SOURCE: Water leaks from the shower head. I have a delta
You may want to replace the ball or cartridge whichever the case may be. Also be sure to use Genuine Delta parts as they will hold up much better than the aftermarket parts. I hope this helps.
Posted on May 27, 2010
packrat1948
  • 528 Answers
SOURCE: where is the filter screen in my delta hand held
I is at the end of the hose where it attaches to the hand held head.
Posted on Jan 31, 2011
Do you need plumbers tape where the handheld shower connects to the hose?
No tape is needed. As a matter of fact, taping the threads will make it harder for the swivel nuts on either end of your hose to tighten down and seal on the black washers that are supposed to be inside those nuts. It's exactly the same as a garden hose connection. No tape required.
Aug 07, 2014 | Oxygenics Hand Held Multi Function Shower...
I have a delta in2ition shower head. The shower arm has a water outlet head that is screwed down onto it (the water outlet head is round like a ball and has a hole in the middle of it from which the water...
Take the gasket to your local hardware store and have them match it up.The answer is no, the gasket is not supposed to be split. It was probably tightened too much.
Jul 24, 2011 | Delta & Single Handle Shower Faucet
Where is the filter screen in my delta hand held shower head
Jan 31, 2011 | Delta RP48770PB Traditional Three Function...
Connected shower head to hose and the hose connection to shower head leaks back toward line. There is a white end over the inside of the end of the hose. I believe this restriction is causing the line to...
I understand that the white vac breaker end should be connected to the valve not the hand shower. FYI a little leak from this connection when the water is switched off is normal.
Sep 27, 2010 | Water Pik Shower Head
Remove and replace a hand held shower head hose in whirl pool
Hey Rick........the connectors are just large nuts at each end of the hose. If you remove one of the connectors there should be a a ring slipped around a grooved part of the hose with a plate. If you remove the clip the plate should slide off enabling you to remove the hose. Let me know if you need any more help.
Thx
Ken
Aug 16, 2009 | Price Pfister Roman Tub Hand-held Shower...
No hot water
May 28, 2009 | Delta & Single Handle Shower Faucet
May 18, 2009 | Delta & Single Handle Shower Faucet
Water trickles out of hand help head
the problem is probably not in the actual head but in the valve body where the diverter is attached. It is easy to google something like "how to change the washers on a faucet" and you will find step-by-step instructions on how to do so.
http://www.dummies.com/how-to/content/how-to-replace-a-washer-in-leaky-faucet.html
May 16, 2009 | Delta Faucet Delta 75582 In2ition 2-in-1...
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
933 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
