Question about Jenn-Air JJW8230D Electric Double Oven
Element burn out bottom jennair stove
Element burn out bottom stove jennair SVD48600p
repain man replaced element and main board with clock
stove still would not work but he did not know what else
could be problem
  • 716 Answers
No error code?
Clock works?
Stove-Top Works?
Broil doesn't work?
Bake doesn't work?
Convection doesn't work
The convection fan runs?
Self Clean doesn't work?
He replaced the control board?
Posted on Jan 13, 2009
  • Jenn-Air Master
  • 19,396 Answers
Test the sensor probe , and test the wiring harness to find out shorts or broken contacts.
I assume the thermal fuse had already been tested.
It will be useful to know if there is power to the element, and if the oven does not heath, is on error state, or there is no power at all on display.
    Sergeant:
    Novelist:
  • 326 Answers
Just check whether the element is getting required voltage if not check the internal connections properly.
Jennair svd48600w broil element will not turn off, fan runs continuosly. had clock issue & just replaced same. clock working. relay board?
I am very sorry to hear of this matter. Please contact JennAir directly at (800) 536-6247 for further assistance, or email us at JennAir.digital@jennair.com
Thank You,Jordan P.
Sep 22, 2011 | Ovens
My sister's oven element burned out. Never having replaced one before, I asked a friend how to get it out & he told me. I asked about turning power off & he said as long as the oven is off no need....
First, you should always turn the power off to replace the element. One side of the element always has 120 VAC applied and it turns the oven on by applying 120VAC to the other side giving 240 across the element. Most ovens have L1 branching out to both the bake, and broil elements, and it also branches out to the control board and all of the switches that run your top elements. If you don't have an element in the bottom, its likely that L1 is grounded out and is tripping the breaker as soon as it's turned on. So if you install the new element it should fix your problem, however if it doesn't you might have burned up the L1 wire somewhere and will just have to trace it back.
Jan 30, 2011 | Ovens
Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
Nov 03, 2010 | Kenmore Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Feb 12, 2010 | Dacor ECD230 Epicure Electric Double Oven
Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Oct 08, 2009 | Jenn-Air Ovens
Bottom oven element not working
Only 2 things left. A bad wire or bad control board.
Remove the rear panel. Set the range to bake,check power at the element terminals with a voltmeter. Ifyou do not have 220 volts at the element replace the ERC.(clock).
May 23, 2009 | GE Ovens
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Jennair flashing f7
by he tried the eraser for freeing the stuck button you mean he cleaned the mylar ribbion then my best advice from my experence is replace them both that way youve got it on one teardown its almost impossable to nail it to just one part
Jun 17, 2008 | Ovens
Electric surge turned off the clock,oven but the stove top works
The clock and display are leds, right. If you can remove the panel where the board is and gain access to the back of it, look for a fuse, similar to a car fuse. The elements are controlled by manual independent switches, that's why they are working. If there is no fuse, or its still good, look for a burnt wire of some sort back there, as you said a power surge went through it.
Feb 19, 2008 | Ovens
Jenn-Air JJW8230D Electric Double Oven Logo
108 people viewed this question
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
