Question about Alesis DM10 (Module) High Definition Drum Module W/Dynamic Articulation
My alesis dm10 hd drum module won't display anything.
It displayed on initial startup, but nothing now. It lights up but is only a blank screen.
4 Suggested Answers
  • 5603 Answers
SOURCE: My Alesis D4 Drum Module shows squares in the
Open the unit and see if it has a battery that holds the settings. Check the voltage... it should be around 3 volts. If less than 2.5 volts replace it.
Verify the INTERNAL regulated power supply as the external you verified with new unit. The external is likely regulated within the D4 and either due to an overload or bad regulator may be below the voltage to run the processor. It is likely 5 volts and anything over 4.85 would be acceptable.
Posted on Jul 28, 2010
  • 5603 Answers
SOURCE: I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
Posted on Feb 08, 2011
  • 5603 Answers
SOURCE: Alesis DM6 electronic drum kit module sound
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
Posted on May 08, 2011
Anybody ever figure out the Alesis DM10 module blank screen with some led lights on?
Try a reset before going to assistance:
There are two ways to reset the DM10:
To fully restore the module to original factory settings, hold the EXIT and STORE buttons while powering on the module.
To reset only the kits, sequences, or trigger settings:
  1. Press UTILITY to enter the main Utility Menu.
  2. Press SYS (F4) to access the Accompaniment Settings.
  3. Press INIT (F2) to access the reinitialization page.
  4. Use CURSOR UP/DOWN to move through the following menu items:
    • All Kits: All of the module's kits and their settings will return to factory default
    • All Sequences: All of the module's sequences and their settings will return to factory default
    • All Trigger Settings: All of the module's trigger settings will return to factory default
  5. Highlight the option you would like to reset, then press EXEC (F4).
  6. A window will appear asking you to confirm your choice. To confirm and reinitialize the selected settings, press YES (F1). To Cancel, press CANCEL (F2 or F2).
Aug 20, 2015 | Alesis Music
ALESIS SR-16 won't save patterns
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
Nov 08, 2014 | Alesis Sr 16 Stereo Drum Machine
I have a dm10 and I keep getting
UNPLUG A TRIGGER. PLUG BACK IN AND HIT O.K.
Sep 29, 2012 | Alesis DM10 (Module) High Definition Drum...
Kick drum and cymbals will not trigger if i hit them at the same time
Have a look in the manual for advanced settings related to crosstalk between pads. You can adjust, for example, so that one pad isn't causing another to react...common issue and can usually be configured to tell one pad to not react if one or several specific pads are struck. Sounds like yours are set too high for that rejection.
Aug 05, 2012 | Alesis DM10 (Module) High Definition Drum...
I need help my new dm10 mod comes up with calibration fail when I turn it on even with nothing plugged into it. I have updated the firmware it just wont talk to the kit at all
you have to make sure the red crash 1 is on the cymbal w the choke zone on it and plugged into crash one on the module. crash 2 goes in the cymbal w no choke and plugs into perc 2 on the module. also make sure the ride zones are plugged in to the corresponding zone on the module. bottom line double check all connections and reference the setup guide if u still have it. i had the same issue.
Jul 22, 2011 | Alesis DM10 (Module) High Definition Drum...
Feb 08, 2011 | Alesis DMPad 8" Dual-Zone Drum Pad
My Alesis D4 Drum Module shows squares in the Display screen and both the both the Store and Note Chase light come on and stay on. I have tried both a new power supply and pushing both the Voice and Output...
Jul 27, 2010 | Alesis Sr 16 Stereo Drum Machine
I can't get my dm5 drum set to play,I have reinitialized the sound module and it does not make a sound.
DO the initialize again as on this site:
http://www.hartdynamics.com/support/alesis.html
and follow the directions about setting each pad volume and the dynamic =1
Feb 05, 2010 | Alesis Sr 16 Stereo Drum Machine
Blank display no functions power ok
Not sure what you mean by "power OK",
If you have checked that the logic circuits are getting a clean 5 volts DC THEN the power is OK. This requires an oscilloscope AND a voltmeter.
USUALLY when a display shows characters like that it means the processor hasn't initialized the display. Most common problem is too low power supply that doesn't permit the processor to come out of reset.
Bad filter caps can cause the 5 volts to dip below 4.6 volts which would be minimum to operate. A voltmeter might still register near 5 volts but a scope will show the voltage dips.
Jan 12, 2010 | Alesis Sr 16 Stereo Drum Machine
Alesis DM10 (Module) High Definition Drum Module W/Dynamic Articulation Logo
300 people viewed this question
Top Alesis Music Experts
drivealot
Lawrence Oravetz
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
