Question about Panasonic Heating & Cooling
Air Contional Model CS-C9NKH, auto switch in OFF mode. Use remotecontrol to set ON but still in OFF mode. Why?
It is a new model and we just start using today. About few hours later, the air conditioner automatic switch to OFF mode. Remote control has no way to turn it to ON mode.
bobotfel
  • 236 Answers
SOURCE: Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Posted on Jan 02, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
Model CS-E12NKR. What does error code F99 indicate?
Outdoor Direct Current (DC) peak detection
7 times occurrence continuously
Check: • Outdoor PCB
• IPM (Power transistor)
• Compressor
Chances are that the outdoor board has gone. You need a megger to check the compressor first before buying a new board.
Nov 13, 2015 | Panasonic Heating & Cooling
My air con just suddenly stop blowing air and the timer button just starts blinking. every time i switch on the aircon it will auto shut down and the timer button lights up please help me to fix it.
Owner's manual? troubleshooting? Possible it's smart enough to know you have an air filter that needs changing or cleaning.
No manual? Try MFG web site, or email their customer service, or try manualslib.com
Apr 02, 2015 | Panasonic Heating & Cooling
Goodman mini split model # wmh24-1a error code snowflake light stays on and 4th light from left blinks. i need to know what that means?
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
Apr 28, 2011 | Soleus Mini Split Air Conditioner
What mode on my model hprbo7xc7 is for air
Hi, On all model stats, the mode you want for the fan to cycle off and on with the air conditioning, is cool-auto, not cool-on. With cool on, the indoor fan will continue to run all of the time. In the auto mode, it will cycle on and off.
Sincerely,
Shastalaker7
Jun 27, 2010 | Heating & Cooling
What do the controls on a portabel AC mean. Like the mode button.
my 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Oct 07, 2009 | Heating & Cooling
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off...
there is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Sep 27, 2009 | Electrolux E23CS75SS Air Conditioner
Maytag-M7Y10F2C Trying to select the most efficient setup mode.
Just set it to auto and set the thermostat as high as you can stand it.It will shut off when it reaches the temp that you set and stay off until needed again
Jul 30, 2009 | Maytag M6Q10F2A Air Conditioner
Air handler fan runs nonstop in heat mode
is this a new problem? the fan speeds can be adjusted by changing wiring connections. If it is a new problem on an existing system then it could be the t-stat or a problem with the curcuit control board. the switch on the t-stat for FAN is set to auto not ON. if set to on the switch to auto - problem solved.
Nov 26, 2008 | Heating & Cooling
Heating & Cooling Logo
94 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
