Question about Panasonic Heating & Cooling
Air Contional Model CS-C9NKH, auto switch in OFF mode. Use remotecontrol to set ON but still in OFF mode. Why?
This is new one that just use for today. Start to use is fine but few hours later, the air conditioner auto switch off and no way to turn it ON even the remote controller can control the switch mode.
bobotfel
  • 236 Answers
SOURCE: Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Posted on Jan 02, 2008
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
This is the standard meaning of symbols in the remote control.
Posted on Mar 02, 2008
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
SOURCE: How can I get Westpoint air conditioner wireless remote controls?
Dear,
Do you mean thermostat, the wireless controller for air conditioner? we are exporter of this line from China. Should you be interested in our products. Please feel free contact me at leeysea@gmail.com or add my MSN lee_ysea@hotmail.com. Our website is www.yseagroup.com
Thank you!
Lee Lee
Posted on Oct 20, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
I am new to a heat pump. The thermostat has an 'auto' setting and an 'on' setting. I am confused as to which one to use for heat. Can you help me?
n most heat pump thermostats you have two control switches and the temp setting. One control switch will say "Heat", "Off", "Cool" while the other says "On" and "Auto". The three position switch is for whether you are heating or cooling. The two position switch is for the fan control. "On" will make the fan run constantly whenever the three position switch is in HEAT or COOL mode. Some people use this to circulate air at all times. MOST people use the AUTO mode, where the fan is controlled by the circuitry and runs during the times of heating and cooling only.
Oct 16, 2015 | Heating & Cooling
My air con just suddenly stop blowing air and the timer button just starts blinking. every time i switch on the aircon it will auto shut down and the timer button lights up please help me to fix it.
Owner's manual? troubleshooting? Possible it's smart enough to know you have an air filter that needs changing or cleaning.
No manual? Try MFG web site, or email their customer service, or try manualslib.com
Apr 02, 2015 | Panasonic Heating & Cooling
Goodman mini split model # wmh24-1a error code snowflake light stays on and 4th light from left blinks. i need to know what that means?
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
Apr 28, 2011 | Soleus Mini Split Air Conditioner
What do the controls on a portabel AC mean. Like the mode button.
my 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Oct 07, 2009 | Heating & Cooling
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off...
there is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Sep 27, 2009 | Electrolux E23CS75SS Air Conditioner
Maytag-M7Y10F2C Trying to select the most efficient setup mode.
Just set it to auto and set the thermostat as high as you can stand it.It will shut off when it reaches the temp that you set and stay off until needed again
Jul 30, 2009 | Maytag M6Q10F2A Air Conditioner
JVC camcorder won't work inside at night anymore.
check the following in camera mode and the auto/manual switch set to manual:
exposure: set to auto shutter: set to auto or off agc: auto white balance: auto program ae: off gain up: auto display/bright: +1-+3
after all that, hit the auto/manual switch again to set the camera into auto mode, the new settings should sort you out.
Jul 28, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Air handler fan runs nonstop in heat mode
is this a new problem? the fan speeds can be adjusted by changing wiring connections. If it is a new problem on an existing system then it could be the t-stat or a problem with the curcuit control board. the switch on the t-stat for FAN is set to auto not ON. if set to on the switch to auto - problem solved.
Nov 26, 2008 | Heating & Cooling
Hi i have a cs-w24ekr air conditioner. The problem is it blow's cold air when set to heat even at 28degrees.
you have pressed the mode button on remote until it has said heat aswell? becasue 28 degrees in cool mode will still seem cold unless the mode is also set to heat.
Aug 12, 2008 | Panasonic Heating & Cooling
Heating & Cooling Logo
81 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
