Question about HP Pavilion g6-1a50us 15.6in Widescreen LED Notebook PC LH612UAABA, AMD Athlon
Unable to unplug cable from RJ 45 jack stuck on new HP Pavilion G6 notebook
I just purchased this pc new. The Rj-45 network jack plugs into the laptop with no problem and no forcing. But when I try to remove it, it will not come out without an extreme amount of pulling and wiggling. It took me 15 minutes to unplug it and all the time I was worried I was going to pull the guts out of the laptop before the cable would unplug. Should I just send the pc back or is this something that could be easily fixed? Thanks.
    Sergeant:
    Champion:
  • HP Expert
  • 427 Answers
Cable is not good. On the plug of the cable it's a small piece of plastic that keep cable from falling out from jack. Press safety before pulling out. Buy a new cable.
unable to unplug cable from RJ 45 jack stuck on ne - 9abbba21-3c1d-49f0-b02c-4a1be2ad25aa.jpg
Posted on Apr 17, 2013
2 Suggested Answers
parrotheadpc
  • 2600 Answers
SOURCE: RJ-45 port fails to securely seat the ethernet jack
These ports are soldered onto the motherboard. They can be changed out by a tech that has the right equipment. I have been able to successfully pull these off at one time using a heat gun set to high for 15 seconds. Then the solder points need to be cleaned thoroughly and the new jack placed into the brass sleeves of the motherboard and each leg soldered into position.
Posted on Mar 26, 2010
What jack does the Slingbox Ethernet cable hook into on a ATT 2wire modem? I have a choice of DSL or one like the phones are hooked into. It's not working now so I'm backing up each step, no matter...
Before you change anything - is this a new device you are hooking up or had this thing worked in the past? First thing to do is reboot everything starting with the modem and ending with the computer at the end of the line. Wait at least 30 seconds between each device. Review all the connections - everything plugged in where it should be? (this is of course your question - see more below).
Eithernet connections (plugs) are RJ-45. The RJ-45 looks like a RJ-11 (telephone jack) only bigger. Typically, the RJ-45 will not fit into the RJ-11 AND SHOULD NOT. Why? Your Cat 5 eithernet runs on very low voltage and signal (packet switching). If you succedssfully get the RJ-45 CAT 5 cable into the RJ-11 phone jack, when the phone rings, you will be sending 60 volts into your network. Can you spell "Do I smell smoke?" A RJ-11 will have up to 6 wires (one pair or two pair or three pair) in the jack and up to 6 'buds' on the RJ-11 plug. A RJ-45 will have 8 wires (in the jack) and 8 'buds' on the plug of your cat 5.
Your device may say DSL on the Cat 5 connection - count the wires inside or the jack.
There are other Cat 5 connection types, punch down and terminal screw types, I dont think you are talking about either.
On your AT&T modem, you should find a RJ-11 which will attach to a near by telephone jack and a RJ-45 for your Cat 5 cable. Your modem may also serve as a router and as such would have additional RJ-45 ports. I suspect you are using a separate router for your home network. As such, one of the ports on the router should be marked Internet or Upload or maybe it is a special color or is set aside from the other ports. That special port will be connected to your modem and your other computers will use the other, lesser ports.
Of course, you could call your service provider for clarification also.
Thank you for your question @ FixYa.com - I am sorry you are having this trouble and I hope I have helped you in some way. I hope you are able to get your system back up in short order.
If you are pleased with this response, please consider awarding the coveted 4 thumbs up to this response. Thank you
Aug 08, 2011 | 2wire Computers & Internet
How di I terminate the QVS Cat6 RJ 45 plugs?
terminating a RJ 45 plug means to put a RJ 45 plug on the end of a suitable cable. This is done by making up a si\uitable cable and skinning the tips of the cable and inserting them in the right order to the plug and then using a special RJ 45 crimper mashing a plastic plug down on the wires. You can purchase such an arrangement from an electronics supplier.
Jan 06, 2011 | QVS 100pcs CAT6 RJ45 50u Crimp Connectors...
I have a cable modem that doesn't want to accept the RJ-45 cable (I think that's what it is called.) I've tried several different quality cables with no luck. Strange problem. Any tips?
Some RJ 45 jack cable has fault so try with another RJ 45 jack cable .. Purchase new rj 45 jack cable from nearest computer shop. There must be 2 port on modem 1 for ADSL phone line cable and otthr for LAN ethernet port means RJ 45 jack port. Try with another rj 45 jack cable it should be connect.Make sure that LAN port of modem is not faulty means make sure pins on that port are not break. Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Computers & Internet
Mar 26, 2010 | HP Compaq Presario R4000 Notebook
Connecting laptop hardwire from router, the notebook won't acknowledge that it is connected.
Is this XP or Vista or 7? You are silent as to the OS, the computer and the router - making it difficult to narrow down the possibilities.
Have you run the wizard to setup a home of small office network?
Have your run your router's software?
Have you indeed connected your computer to your router using 8 conductor Cat 5 ethernet wire?
You are pluged into a RJ-45 outlet in your computer not the RJ-11 modem connection?
RJ-11 with telephone wire will fit into a RJ-45 outlet but it will not work.
Be advised that if you plug a phone wire into your NIC (Network Interfact Card) and the other end into your telephone jack, when the phone rings, that wire will shoot 60 volts into your computer ... there will be the smell of fried components, the sound of gnashing teeth and the sound of a sash register in your future..
Feb 25, 2010 | Computers & Internet
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at FixYa.com
Please vote.
Feb 17, 2010 | NEC Versa VXi PC Notebook
I want to know and identify the parts of my laptop
On the right hand side starting from the front to the back, the ports are
1. (2) USB Ports
2. TV/Cable jack if applicable, some models don't have.
3. RJ-11 Modem Jack
4. Security cable Slot
5. Power Connector
On the Left side Starting from front to back. the ports are.
1. Express Card Slot
2. Digital Media Slot (below the Express Card)
3. 1394 (firewire) slot (some models don't have)
4. USB Port
5. E-Sata Port
6. HDMI Port
7. RJ-45 Ethernet Port
8. Expansion Port Type 3 (attaching docking station etc.)
9. External Monitor Port
Oct 10, 2009 | HP Pavilion dv6-1030us Notebook
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
Plz explain me exactly for which purpose RJ-45 cable used ?
RJ -45 is a type of connector used on cat5, cat5e....etc cables to connect networked devices...the RJ stands for registered jack but there is really not much you really need to know about it....a RJ 45 JACK is a little bigger than a telephone jack, you'll notice the female type of input on your computer or laptop and the male end will be on the end of the cable that goes into this jack....hope this helps
Apr 13, 2009 | Cat5e Cat 5E Modular Plugs - For Round...
HP Pavilion g6-1a50us 15.6in Widescreen LED Notebook PC LH612UAABA, AMD Athlon Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
