Question about Zanussi Dryers
Zanussi tce7124w dryer keeps shutting off before clothes dry
On any setting, dryer works but stops before clothes dry. It can take days to dry one load as keep turning it on but then it turns off.
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
  • 686 Answers
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
  • 7 Answers
SOURCE: Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Posted on Jul 15, 2009
MNfisherman
  • 11896 Answers
SOURCE: maytag dryer model LDE512 will not turn off when
The timer may be faulty.
Servicing the Timer
Most dryer timers are digital or mechanical. The timer controls most of the operations of the dryer. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the dryer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the dryer. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Aug 25, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
My Zanussi TCE7124W is not running cycles properly and the clothes are still wet at the end of a run
The filters are clogged.
• The condenser is clogged.
• The water reservoir is full.
• The selected cycle is not suitable for the laundry.
• Insufficient drying time.
• The laundry has not been spun properly.
• The low-temperature function selected.
• Excessive laundry load.
• The dryer is not correctly installed.
Also, check the heater elements.
For the movement, check the drive belt has become worn or snapped. To test your tumble dryer's drive belt, we recommend you manually spin the drum. If it is stiff and difficult to move, the drive belt is ok, if it is easy to move, there's a good chance the drive belt is the fault.
Nov 02, 2017 | Zanussi Washing Machines
Fisher and Paykel dryer dries clothes on medium heat but shuts off repeatedly if I set it to normal dry setting.
you probly have a venting problem disconect the vent from the dryer and try it see if it works ok if so get someone to clean vent ducking out.
Mar 26, 2014 | Fisher and Paykel DEGX1 Electric Dryer
Zanussi tce7124w wiring diagram
Hi, I need a wiring diagram for the Zanussi TCE 7124 W dryer, can anyone help?
Aug 13, 2013 | Cars & Trucks
SETTINGS
check the hi-limit switch on the element case or the cycling switch on the motor blower housing,they get weak and cut out too soon and dont keep element hot long enough do dry clothes properly
Apr 11, 2010 | Frigidaire Electric Dryer
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
Zanussin tc7103w not drying clothes
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 17, 2009 | Zanussi TC7114W Electric Dryer
DLE5932W - Not shutting off when clothes are dry - keeps running
You have a computer control board problem and needs to be replaced.  The internal program has a problem and won't time down properly.
Jun 24, 2008 | LG DLE5932W Electric Dryer
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
My zannusi dryer is will not dry clothes on hot setting
thermostat in door part no 1258406014 should do the job colin
Mar 06, 2007 | Zanussi TC7114W Electric Dryer
Dryers Logo
244 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
