Question about Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power
Radio not working on dewalt dc012 - Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power
My dewalt radio dc012 blow fuse in power board,fuse replaced and radio work,after while fuse ok but radio again doesn’t power up
I read this as this: You replaced a blown fuse, the new fuse still looks good but the radio no longer works.
First test the fuse, if it checks out OK then something else has blown in the radio, I check the power supplies first, giving it power and seeing if everything there is still working as it should.
Nov 01, 2017 | Dewalt Audio Players & Recorders
I have a Dewalt charger/radio (DC012 type 1) that was plugged into a 240v US outlet. The radio will come on with a battery in and work just fine, but with it plugged in it will not charge or play.
You burned out the AC circuit. Congratz, at least your radio still works. Use it on battery or take it to a radio technician to diagnose if it can be repaired. Presume it's worth.
DEWALT DC012 Worksite Charger Radio
Jun 25, 2015 | Dewalt DC012 Worksite Charger/Radio
Dewalt dc012 radio charger better reception
Place the radio near a window that is not blocked by neighboring buildings. For AM rotate the radio to find the best reception.
For FM, deploy the telescopic antenna.
You may try to get special antennas.
May 30, 2014 | Dewalt Audio Players & Recorders
Dewalt dc012 won't run on 120v?
change tranformer for converting 12 volt from 110
May 06, 2014 | Dewalt DC012 Radio/charger,120v Ac Or 7.2...
Radio will not work on AC
check ac wire & its connecting jack,then step down transformer
Apr 19, 2014 | Dewalt Dc012 Worksite Radio With Built-In...
I need to know if there is a fuse in the dewalt DC012 worksite charger radio
From what i gathered there are two
Fuse (part No. 5140019-09)
Fuse 1A (part No. 429790-32)
Jan 06, 2013 | Dewalt Dc012 Cordless / Corded Worksite...
My Dewalt dc012 radio will not work while plugged in, it only works with a battery
There is a small transformer which is used to lower the voltage for the radio to use (12 Volts I think) These transformers have been known to be defective at times. You can pick one up at the Dewalt store for about $25.00 and install it yourself.
Dec 29, 2012 | Dewalt Dc012 Worksite Radio With Built-In...
Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power Logo
191 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
