Question about Invicta Watches - Womens 1613 Watch
Is the Invicta 1613 a quartz, automatic, or manual wind?
I received the Invicta 1613 I ordered in the mail today but it is not working. Before I send it back how do I determine if it is a quartz or automatic watch? If it requires a new battery I will be returning.
  • Invicta Master
  • 18,394 Answers
If it's a qoartz it will av it printed on the face of watch
Posted on Dec 12, 2012
  • 4 Answers
SOURCE: problem winding a Invicta Skeloton Mechanical Stainless Watch
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
Posted on Dec 12, 2008
escapement
  • 2334 Answers
SOURCE: Invicta watch has loud self winding
Sorry for your Rolex....
In any case you will not be able to to repair watch yourself as it takes skilled man and special tools to do the job.
It is NOT common that the winding rotor is making a noticeable noise, unless you bought second hand watch.
1st cause can be that the rotor fixing screw is loosened and the rotor is touching caseback whilst in move. Then you are the lucky one as the only thing to do is to tighten it properly.
2nd cause can be that the ball bearing is too worn, bridge screwws are loose, rotor axis worn and so on and so on. In this case you may need some part replacement and much more complicated work must be done. As the outcome it will take more time to repair and you will pay more money.
Regards
Arthur
Posted on Dec 17, 2008
  • 183 Answers
SOURCE: new automatic watch keeps stopping
You can wind this watch until it is snug. If it does not continue to run during normal wear then you should have the watch looked at. The swing weight or main spring maybe malfunctioning. If you can return it under warranty that would be best.
Posted on Sep 18, 2009
  • 9 Answers
SOURCE: how do i set the gmt on my Invicta Men's Pro Diver
Set it only at night but not between 8 and 2. Use the johnson rod that came with it.
Posted on Jan 01, 2010
SOURCE: Need the instructions manual for Swiss ISA 8173
there manual is to general and not watch specific like it should. I would want just a "Chevy" manual for Corvette.
Posted on May 24, 2010
My invicta reserve Zeus bolt stopped working after not wearing for a little while and now I tried winding back up and it doesn't want to work
Most Invicta Bolt Zeus watches have a quartz movement and require a battery. I'm not sure there is any Zeus with a mechanical movement that needs winding. A jewelry store should be able to change the battery for a small fee if that's what it needs.
Mar 21, 2016 | Invicta Watches
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
How do I windup my invicta pro diver 9309 watch
YOU DON'T WIND IT UP ITS QUARTZ THAT MEENS ITS BATTERY OPERATED AND PROBABLY NEEDS A NEW BATTERY
Oct 21, 2014 | Invicta Swiss Pro Diver 9309 Wrist Watch
How do I wind my Invicta 1805?
My very brief research shows that the Invicta 1805 watch is driven by a Japanese quartz movement. That would certainly explain why you're having trouble winding it.
The easiest check for quartz vs. mechanical is to observe the second hand. If it pulses only one time per second--i.e., jumps one second at a time--then you're looking at a quartz movement (I'm ignore the rare and expensive mechanical jump movements). If it looks like the hand takes 4 or more little jumps to get from one second to another, you have a mechanical movement.
Dec 01, 2012 | Invicta 1805 Watch Mens Russian Diver...
Invicta 8926A gains about 2 or 3 minutes after winding.
Send in for warranty repair with a description to Invicta
Oct 12, 2012 | Invicta Automatic Pro Diver 8926A Wrist...
Does my watch have a battery or do i have to wind it? I tried winding it but it still isnt working I just want to be sure before i bring it to a repair shop. I thank you in advance. Thomas
mcdevito75 here, If you try to wind your watch listen for the distinctive click, click as you wind, if you haer this click, click then it"s a a windup, if the stem just turns without the distinctive sound click, click. then it"s a battery watch, also look for any word on the watch that says Quartz. ONE more thing, you may have a screw down cover on the winding stem, un screw the cover on the stem to get to (the crown, winding stem itself) Most likely you have to un-screw this cover on the stem to get to the actuall stem itself, Invicta makes watches like this to add waterproofing to the watch.
Nov 19, 2010 | Invicta Corduba Luminous Multifunction...
Brand new today out of the box and will not run Tried winding and shaking. Second hand will not move.
mcdevito75 here, Use the waranty info from the box and call Invicta. In the meantime, turn the winer stem and hold the watch close to your ear do you hear a clicking?? Some automatic watches will only wind while they are in motion on your wrist, Hold the watch in your hand a turn your hand in circles and see if the watch starts up.
Jun 17, 2010 | Invicta Automatic Pro Diver 8926 Watch
New automatic watch keeps stopping
Jan 31, 2009 | Invicta Automatic Watch
Problem winding a Invicta Skeloton Mechanical Stainless Watch
Dec 12, 2008 | Invicta Watches
Invicta Watches - Womens 1613 Watch Logo
128 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
