Question about Refrigerators
Godrej pentacool semi automatic defrost ...water is leaking out..switc off in the interior is to switch off the defrost or whole of the fridge
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: semi automatic defrost button won't pop up
The switch is broken and needs to be replaced.
This happens a lot
Huum
Please remember to leave feed back .
This is the answer.
click solve please1
Posted on Dec 09, 2008
Refrigerator leaks onto floor?
when fridge goes into deffrost water from defrosted ice should drain to underneath fridge. drain could be clogged.... or ice has buily up over drain hole.
Sep 01, 2014 | Refrigerators
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
Aug 21, 2014 | Refrigerators
Why does my whirlpool ET25DQ refrigerator leak water?
If your refrigerator has automatic defrost, the defrost water should drain from the bottom rear of the interior into a drain pan underneath. The pan may be missing or damaged or something could be preventing the defrost water from draining into the pan
Aug 05, 2013 | Whirlpool Refrigerators
I have a magic chef refrigerator model # mcbr415sf. The top freezer part does not get cold enough to keep ice cream cold, but when you turn the temp up -- there is only one temp control and that controls...
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
You can fix this by yourself and do take care in solving the problem......
May 12, 2011 | Refrigerators
There is compressor sound problem in godrej pentacool refrigeratore
Im taking that you have a fridge that works fine you just have a noise that is bothersome. The easiest way to correct vibration noises is by pushing on the compressor or surrounding coils until you find the offening spot of vibration. You can buy damper pads but you can use a piece of cardboard wrapped in duct tape. Fold it so it is thick enough to wedge into the area that is vibrating to get rid of the noise. good luck
Aug 18, 2010 | Refrigerators
My GE fridge is leaking water on the freezer side
This would be due to the defrost drain being clogged. The automatic defrost cycle melts the frost on the evaporator every few hours and the water from that is suppose to flow down a drain tube, if the drain becomes restricted the water will leak out the freezer door. Here is a link to some instructions I put together on how to clean it out.
Defrost Drain Cleaning
Jul 18, 2010 | GE Refrigerators
Leaking water from the actually fridge over the floor.
manually fully defrost unit,clean all vents /drain pipes
make sure door seals touch all round(no air gaps)
use bicarb to freshen interior and dry as best you can
then switch on and hopefully,if unit is working normally,enjoy...only place cold food in fridge to minimise ice build up.(some fridges have a drain vent in the centre bottom of door to allow water to drain when defrosting
Feb 14, 2010 | Refrigerators
Godrej Pentacool Model No GF21 is not cooling properly, please solve this proublem.
godrej pentacool get more moisture plaese solve this problem
Feb 13, 2010 | Refrigerators
Ice build up condensation will not drain down the tube to the catch pan under the refiridgerator. As much as 3 inches of ice will build up between the veg bins, causing mold builup in fridge, Model 550...
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
Feb 17, 2009 | Sub-Zero Bottom Freezer Refrigerator
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
