Question about Kenmore Washing Machines
Kenmore elite washer 23012101 Agitator Not working
Lumpy816
  • 246 Answers
SOURCE: Top Portion of agitator does not work
110.23032102 shows as a kenmore model number. I couldn't find a matching part number, so we'll work off the assumption that it is the model number. That being the case, if just the top portion of the agitator does not work, you are likely looking at and agitator dog problem. Yes, it's a silly name for the part, but that is what it says right on the manufactures replacement part. While you are in there, I would also recommend replacing your thrust spacer as well as they get brittle over time. So, once you have part numbers 80040 (agitator dogs) and 8055228 (thrust spacer), here's how to swap them out. First remove your fabric softner dispenser. It should have a blueish/ green ring around it. The ring locks it in place. Lift the ring and the dispenser will lift off. Next, as you look down under where the dispenser was, you will see clear plastic with a black rubber ring around it. There are 2 tabs sticking out of the top of it, just grab these (needle nose pliers would make it easier) and pull it up. Under that you will find a bolt (7/16" if I remember correctly) Remove the bolt and the whole agitator can lift out now. If only the top half comes off, don't worry about it. the bottom half can stay without a problem. As a matter of fact, the thrust spacer sits between the 2 halves. Now, the area where the bolt came out is a seperate piece. It may or may not be held in by two white plastic tabs at the bottom. If it is, just work the tabs off with a small flat head screwdriver. Once this piece is seperated, you will now see your agitator dogs. There is a ring holding them on from the bottom. Slide the ring off and replace all 4 dogs. Wipe any extra fabric softner and shavings from the previous dogs out. Re-assemble in reverse. .
Posted on Jul 09, 2008
SOURCE: model 110.22952100 Kenmore Elite Heavy Duty Washer
how to remove agitate from a kenmore elite
Posted on Oct 03, 2008
Maytag317
  • 1136 Answers
SOURCE: replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
WonderTech
  • 268 Answers
SOURCE: my agitator is not working in my washer- it is a
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Posted on Aug 07, 2009
  • 1937 Answers
SOURCE: dual action kenmore 70 series washer need to remove agitator
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
1. Remove the fabric softener dispenser.
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Posted on Nov 06, 2009
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
How to remove the agitator & the basket on a kenmore elite oasis
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator on my washer is loose
Replace the agitator dogs in the top part of the agitator. Parts are about $7.00.
Jul 17, 2009 | Kenmore Washing Machines
Agitator looks like its stiped on my kenmore elite top load washer
kenmore top loaders have two piece agitator .down inside there are 4 little plastic pieces called dawgs .top should rachet in one direct. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Washing machine agitator upper half not working I have a Kenmore Elite
Pull the fabric softener cap off, next pull the top cap off the agitator. Then remove the 7/16 bolt in the center of the agitator. Then you can remove the top part of the agitator.
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
120 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
