Question about RCA Televison & Video
Rca lcd tv rcl3257b dose not work when turn on have to switch on button a few times before it comes on
SOURCE: RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Posted on Dec 25, 2007
mjap
  • 107 Answers
SOURCE: RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Posted on Jan 19, 2008
  • 899 Answers
SOURCE: My HD50LPW166 will not turn-on...
unfortunately all of these types of tv's are failing from poor craftsmanship , poor quality components , thus leading to inevitable break down ( just poorly made) if you want some technical info just click helpful and leave a note . I can help determine the cause if you want to get into the tv , otherwise you will need to call a repair shop to get it fixed
thanks for using fixya!
electech
Posted on Oct 19, 2008
  • 17 Answers
SOURCE: RCA Universal Remote #RCR451
Many times someone will accidentally push the wrong button, or some remotes have tio be re-set when batteries have been removed and the code needs to be re-set. Go to remotefinder.rca.com/default.aspx?site=rca for your code. Sometimes more than one code is given for an individual remote. All must be tried until the proper one is found.
Posted on Oct 30, 2008
  • 259 Answers
SOURCE: viewsonic 32" N3250W LCD TV won't turn on
by what you say it sounds like the power switch but i am no expert when it comes to tv's hope this helps regards Jim
Posted on Apr 18, 2009
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Missing code for comcast remote to work new rca tv
Hit tv then hold the setup button untill in flashes....then you type in 991 and then hit tv power tv power.... untill your tv turns off when it dose hit setup to lock the code
Jun 11, 2009 | RCA L32HD31 32 in. LCD HDTV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
