Question about Canon BubbleJet i560 InkJet Printer
Printing lines Our printer started printing evenly distributed, horizontal lines across all of our documents. At the same time, we were running out of ink so we replaced all the color cartridges just in case the low ink was also causing the lines. We replaced all color cartridges and are still getting the evenly distributed, horizontal lines. Is this a fuser issue or is there a way to fix this? Thank you.
Hi. I've been looking for a solution to this very same problem, but I think that the only way to fix it is to replace the print head. I've spent a few hours now trying to find out if there is something else which could cause this problem, and the only one that applies to me (and to you, if you replaced all of your ink cartridges), is that the print head is no longer working. I found a print head for $50 at http://www.precisionroller.com/k_canon_i560_print_head/m114d5908c104/ , so I'll probably go that route.
Posted on Jun 11, 2007
Our printer is printing horizontal lines across
open the front door and press the green button in the center upper ,remove the waste toner collector ( carefully it will spill if turned over ) you will see four green knobs small diameter these are cleaning rods ..pull them out about a foot they will stop push them back in four or five times each color there is also a wand on the door and it fits pad down in the slot below the green rods slide it in and out to clean the laser....if this does not do the trick you will need service refr to you manual for cleaning if you have it
Feb 16, 2010 | Sharp MX-2300N Color Copier
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Feb 05, 2010 | Canon PIXMA MP610 InkJet Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
Printing with a black horizontal line across bottom of the page
Wipe the cartridge.Use cotton but dont put water on it only cotton.if you have deiones water its good to use.
May 20, 2009 | HP LaserJet 5550DN Printer
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Epson stylus photo R2400
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
Jul 31, 2008 | Epson Stylus Photo R2400 InkJet Printer
Printer
I need to know if this is a sudden occurence or has it happened before. Is cartridge new or refilled or older, and did it print right until now. Also need to know if you have made any recent system changes and if you run anti virus and spyware.
Mar 12, 2007 | Lexmark X1195 All-In-One Printer
Canon BubbleJet i560 InkJet Printer Logo
181 people viewed this question
Clive
Clive
old marine
old marine
