Question about GE Refrigerators
Ge profile. top fridge door hinge bolts stripped. How to reestablish solid bedding ?
Pss23sgsa ss
5 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: GE Profile Door Stop Bracket Replacement
Hi, get me the model# and I get you exact answers to all your questions. It is not a hard job.
Vic
Posted on May 17, 2009
  • 56 Answers
SOURCE: Top lock on GE Profile Fridge is broken
bad news you have to replace the door gasket
they only sell them in pairs and not cheap
Posted on Jul 03, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
Ge profile self-Cleaning oven: how do I clean between the glass door. Where do I take t apart?
Hello Patricia
Oven doors by their design are very difficult, almost impossible to open then re-assemble. Not advised.
However, for the brave-hearted, oven doors can be open, eg to change a broken spring etc.
This involves dressing in protective gear as glass fiber wool insulation inside stove and door casing is very hazardous.
Strip half the stove to get to the hinge/arm mountings, unbolt so that door & hinge-arms come free, lay face-down on newspaper.
Using brute strength, unscrew Philips screws which have stuck solid from years of baked fat and heat.
Lift carerfully and try to avoid itchy glass fibres.
Glass inspection hatch insert may have stuck to silicone seal so press until it falls free.
Clean glass & re-assemble all in reverse order.
Trying to get the hinge-arms to line up while holding the heavy door is the most difficult part.
Can lead to stress, premature ageing....
Hope this helps :)
Clive.
Oct 29, 2017 | GE Kitchen Ranges
How to remove freezer door with water/ice dispenser on GE profile TFH22PRSM
TAKE OFF KICKPLATE ON BOTTOM OF UNIT. UNHOOK WATER LINE FROM QUICK CONNECT UNDERNEATH. ON TOP OF FRIDGE THERE IS A COVER OVER THE DOOR BRACKET. REMOVE THAT COVER. THEN REMOVE THE 2 OR 3 SCREWS HOLDING BRACKET TO TOP OF FRIDGE. THEY USUALLY ARE 5/16TH SCREWS.MAKE SURE THE HAVE DOOR SHUT OR SOMEONE HOLDING THE DOOR WHEN DOING THIS. AFTER REVING SCREWS AND BRACKET LIFT DOOR UP OFF BOTTOM HINGE AND WATER LINE FROM DOOR WILL COME OUT WITH IT.
Jan 17, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
. I need the hinge door stop on the lower right side of refridge
The door stop part # WR02X10782 If this is for the refrig door , check the screw at the bottom of the door , to make sure it is not adjusted too high , bypassing the door stop . The same door stop is used on both doors .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge door not closing 100% at the top.
Loosen the screws holding the top door hinge. Pull up on the freezer door and hold it while you re-tighten the hinge screws.
Dec 31, 2009 | GE Profile Arctica Stainless Steel Top...
How do we adjust the door height on our GE Profile Side by Side frig, Model TPX24BPZC...it has slipped down and the trim kit keeps rubbing on the lower edge where the door hinges....????
Hello, Take the cover off the top hinge and then remove the top hinge and the door, the problem may be a worn hinge cam, if it is replace it. If the hinge is loose tighten the bolts. Once the door is off you will see how the lower hinge can be adjusted. Hope this helps! Mike
Dec 02, 2009 | GE Refrigerators
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Jul 03, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
GE Profile door
lose the top hinge and pull the door just a bit. then re thigh the hinge on the new position.
Dec 01, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Creaking Sound when Opening Door of GE Profile PTS22LHSCC Refrigerator
My GE creaks too, and it started after we pulled it out for cleaning. It is normally the door hinges. Spray them with Jigaloo which is a dry silicone lubricant.
Try this. Go to your local tire repair place. Ask them for an old inner tube. Cut a double thickness square with scissors and put it under the 4 corners under where the wheels are. It should help them to become self leveling and also sound insulating..
Mar 23, 2017 | GE Profile PTS22LHSCC 33" 21.7 Cu. Ft....
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
