Question about Dewalt DC614ka cordless nailers
My nail gun turns on but won't shoot and the light comes on five times
SOURCE: dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Posted on Dec 04, 2008
SOURCE: My nail gun will shoot one nail and then stop shooting.
check with one of your friends that have a nowinly good 18v bat if that dont work check for little pieces of plastic or pieces of the nail that are jamed up by the plunger
Posted on Apr 22, 2010
SOURCE: nail gun doesn't shoot and air blowing out vent
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Posted on Oct 21, 2010
SOURCE: i have a 18 gauge 2" brad gun when you plug the
Increase air pressure.... you're way too low......
Posted on Mar 28, 2011
  • 119 Answers
SOURCE: My dewalt cordless finish nail
there is a lock in rear right side (small black rubber thing) us push it back!
Posted on Jul 07, 2011
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
ET200 won't shoot nails. The light works but it doesn't shoot. The chamber is clear of jammed nails HELP!
I had this problem too, and finally figured out what was wrong. If you have cleared a jam and have put the nail gun back together, then all you get is a 'thunk' when you try to drive a brad, you have put it back together wrong, as I did. Take the two screws out and pull out all four pieces -- three plates and one skinny 'T' shaped piece. Look inside the unit and you'll see a pointed piece, which is the hammer that drives the brad in. This next step is key: put the first plate back in (the one that is flat on both sides) making sure that it slides in UNDER the hammer. The hammer fits loosely in its housing, so it may help to turn the nailer upside down so that the hammer falls down, giving you the room you need to get the plate in--again, so that it's UNDER the hammer when you turn the nailer back over. Once you have done this part, simply slide the second piece in (the one with the fluted strip down the middle), slide it in fluted side up, then the 'T' piece (with the 'T' in first) then the last piece with the wider groove that contains the 'T' piece. Replace screws and you're back in business! This information may be in the instructions, but I have long ago thrown those away.
Oct 26, 2012 | Arrow ET200 Electric Brad Nail Gun
The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Oct 18, 2012 | Arrow ET200 Electric Brad Nail Gun
My ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to www.ereplacementparts.com and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
Jul 22, 2012 | Nailers Ridgid Finish Brad Nailer R213bna...
Bostitch N80SB won't reset after firing
Most likely just needs piston oring. Remove nails from the gun and point nose of gun up then down again. If the piston travels up and down in the cylinder, replace the oring. The piston returns to top with air pressure and needs good snug piston oring and good lower bumper (if bumper is cracked or missing pieces ~ replace ). Be sure to lube the orings in the headvalve with silicone paste or white grease. Part # ORK11 oring kit will reseal the gun. Good luck with your repair.
Jun 02, 2012 | Stanley Air Tools & Compressors
My Hitachi nv65ah nail gun won't set nails into 3/4 trim. I have played with the turn/screw set adjustment and it is set for the deepest setting. This gun was purchased second hand off e-bay but
If every nail is stopping at the exact same height, a likely reason is the tip of the driver is broken off so it's not long enought to drive the nails all the way to flush. If the height of the nails is slightly different you may have worn or broken o-ring(s) inside the gun and air is leaking around the driver's piston or elsewhere in the gun so that the driver isn't getting full pressure. You can take the gun apart and inspect the o-rings. If you push the driver all the way down the tip should come flush or slightly past the end of the nose piece (not the safety tip). Parts are easy to find online or at a service center if you have one nearby.
Mar 10, 2012 | Hitachi NV65AH 212Inch Coil Siding Nailer
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Dewalt DC614ka cordless nailers Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
