Question about Insignia Digital-to-Analog Converter for Analog TVs
CONNECTING BOX TO TV W/O JACKS
I have no jacks in back of old GE tv. How do I hook up?
  • pschemberger Jan 13, 2009
    just screws
  • jason May 11, 2010
    does it have the RF cable connection on the tv ? or does it just have some screws for the antenna ?
  • 905 Answers
Then you will need one of these coax adapters to antenna
CONNECTING BOX TO TV W/O JACKS - eb01b50.jpg
Posted on Jan 14, 2009
    Sniper:
  • 62 Answers
Go to any retailer and ask for an RF converter for your older model television.
Posted on Jan 13, 2009
How Can you record tv show using a converter box
Hook the converter box cables to the input RCA jacks on the back of the VCR, then hook the output RCA jacks to the input RCA jacks to the TV, Keep the VCR on channel 3 or 4, on the TV in menu scroll through the source settings to find the what source the vcr is using
May 05, 2014 | GE Vg4261 Vhs Tape Vcr Plus 4 Head Hq...
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I have the TV above and the cable man came out to hook-up to cable TV and couldn't figure out how to get the cable box to work on the TV turner. He had to hook it up to the auxiliary jacks on the back of...
is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Jun 03, 2010 | RCA F20645 TV
Connecting my DVD Player to my Digital Converter Box
The jacks from the player go to the same colored jacks on tv. Then after jacks are connected, tv must be on channel AV or Input. that is the channel used by the jacks.
JUST MATCH UP THE COLORS.
Feb 01, 2009 | Coby DVD-224 DVD Player
CONNECTING TO TV
if your television has the two screw input, go to Wal_Mart and tell them you needan RF adapter for an older model television. If your TV has a cable TV type input, then just connect it via the cable input.
Jan 13, 2009 | Insignia Digital-to-Analog Converter for...
AV Jacks....
Hi! Try connecting the wires to the same colour jacks and also chekc for AV button on the remote which is sue to switch the TV between AV 1 or AV 2 mode.
Thanks
Rylee
Jan 12, 2009 | Recoton Advent Advent TS2066A TV
31GT720 GE Stereo Monitor
I have the same TV. Make sure you have hooked up the red, white, yellow leads from the "out" jacks on the DVD to the same colored "in" jacks on the back of the TV. You also have to make sure your TV is set to Video Mode. I do this with the GE remote that came with the TV. There is a WHO-INPUT button on the left side of the remote, 3rd from the bottom. Toggling this button should switch you between TV and Video mode. Hope this works for you.
Nov 15, 2008 | GE 31GT720 31" TV
Sound is ridiculously low
if it is a stereo tv, there should be rca jacks on the back of the tv [red,white yellow] try connecting the rca outputs to a stereo system and see if the volume is any different.there might be a loose connection to the tv speakers inside.if you have a cable box hooked up to your tv, check the connections in back. you can also try bypassing the cable box by connecting the cable wire directly into the tv to see if it's the tv. if it is the cable box try unplugging it for a minute then hook it up again.i had the same problem with my cable box. hooking it up to a stereo system sounds like a pain, but at least you will have sound.
good luck
wg
Jan 30, 2008 | Toshiba 32AF44 32" TV
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
50 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
