Question about Symbol LS2208 Handheld
How to disable enter key for ls2208 scanner - Symbol LS2208 Handheld
3 Suggested Answers
SOURCE: Hand held scanner LS2208
At the Symbol web site they have some instuctions for programming a 'Tab' at each scan.
Follow this link....
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11124&sliceId=SAL_Public&dialogID=58352294&stateId=0%200%209199403
Posted on Jun 21, 2008
SOURCE: how to integrate LS2208 handheld scanner in vb.net
you have to change it to IBM handheld mode and install opos drivers from symbol. then use pos.net to connect to them.
Some computers requires to create some config files to connect through hardware address. It took me like 6 month to figure out but now it works
Posted on May 18, 2009
How to program a bar code scanner to have 2 Tilde in prefix
Hi, to program two tiles before the data you must use Advanced Data Formatting bar codes from the LS2208 Product Reference Guide. You will need to print and scan the following barcodes:
Begin new rule
Send tilde
Send tilde
Send all data that remains
Send enter key (if you need an enter after the data )
Save rule
Go to the Motorola Solutiond Support Portal and search for LS2208 PRG. The guide has also been stored on Fixya.com
Sep 12, 2014 | Symbol LS2208 Handheld
Disable Sleep Mode
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Mar 18, 2013 | Symbol LS2208
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
I use usb base ls2208 my problem is every time
Hi, to make the scanner automatically hit enter print and scan the barcodes Scan Options, Data Suffix, and Enter from Adobe pages 222 and 223 of 342 of the LS2208 Product Reference Guide.
Jan 06, 2010 | Symbol LS2208 Handheld
Trying to disable intellistand beam turn on when LS2208 is placed in stand.
"Hello, Raschult. We have found a solution for your problem. Simply go to Shift into blue help link and go to page 3. You will see the configuration barcodes to enable and disable "Intellistand Mode". Just print out this page and scan the "Disable Intellistand Mode" barcode. That should do it. If not, let us know and we can try something else. Good luck!"
Dec 30, 2009 | Symbol LS2208-7AZK0100S Handheld
Need to program scanner to read first 9 positions of a 17 position code128 barcode.... then add an "ENTER" stroke... then pause, then an F10 Key....
contact Symbol/Motorola Help desk at 1-800-653-5350. You will probably have to use the scan 123 utility, but the LS2208 may not have the capability
Aug 04, 2009 | Symbol LS2208-7AZK0100S Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
When i scan a barcode why do i have to push enter?
Go to http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201bpdf&sliceId=&dialogID=111756507&stateId=0%200%2011492385
This is the quick start guide for the LS2208. On the first page you will see a section titled Carriage Return/Line Feed. Scan these three bar codes from top to bottom. That's it.
Jun 25, 2009 | Symbol LS2208 Handheld
Is it possible to send two suffix in symbol ls2208
Yes it is possible.
You will need to create the following adf rule which you can do using 123scan.
the barcodes generated will be the following:
Begin new rule.
Send Extended key <Enter>
Send extended key <Enter>
Save Rule.
If you can't generate them, I can send you a pdf document with them already created.
Apr 01, 2009 | Symbol LS2208
I have a ls2208 symbol scanner that need to scan code 39.... The example below is return when I scan the following information. It seems to be do stange thing with the first 2 charecters. Can you help?...
Your scanner is set up for full Ascii mode.
$B = CTRL B
%I = >
Re-program to enable "Code 39" and disable "Code 39 Full Ascii"
In Code 39:
$B = Control key on
%I = Tab
Hope this helps.
Jan 10, 2009 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
707 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
