Question about LG 42LG30 42 in. LCD HDTV
Need 4 digit code for my lg tv 37lh3000 tivo remote
5 Suggested Answers
SOURCE: LG 42PB4D 42" Plasma TV
thanks, 11265 worked for me too
Posted on Feb 16, 2009
SOURCE: Getting my Sky+ remote to operate LG TV
can get remote to controk all of my lg37lh3000 but not the volume have tried codes 2210, 1293, 1176 and a few others any ideas please, jan
Posted on Dec 27, 2009
SOURCE: need sky remote code for 37lh3000 lg tv please
Sky remote code for LG LH3000 is 0206. This works for the 37" and the 42" and probably for a plethora of other sizes.
Posted on Mar 18, 2010
  • 36 Answers
SOURCE: I need the 4 digit code for my LG 42LD520 in
Here you can find almost all the Universal remote codes
http://kbase.x10.com/wiki/Universal_Remote_Code_List
you can also manually find it follow your universal remote control user guide If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Mar 05, 2011
TiVo codes fail after volume button learned
TV codes are a unique subset. Other devices are generally more assignable.
Jan 28, 2018 | LG Televison & Video
Tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
How do I finde the panasonic number which conects the tv to the tivo remote
I would go online to TIVO (remote) and look up all codes for a Panasonic TV and try each one out. One will usually work if the your remote or TV isn't too old.
Google search may be easier.
Feb 20, 2015 | Panasonic Televison & Video
LG 42LC2D-UB TIVO Remote Stopped Working
Hi Did you check the batteries,and if they're put in properly.
Make sure you have fresh batteries and not 2 different kinds. then do your codes again. Good luck.
Feb 11, 2014 | LG 42LC2D 42 in. LCD HDTV
Using LG 47LN5750 functions on my TiVo remote control
Old codes do not work with new ones. If you wish to get new codes, check the sites linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://electronicshelponline.blogspot.com/
Jul 29, 2013 | Televison & Video
Need codes to set tivo to lg tv
Code 0011 worked on my LG 42in LCD.
Thanks to Priya darshan for the codes.
BTW, code 0001 only partially worked ("Mute" did not work).
I phoned Tivo help desk (I am in New Zealand) and they confirmed that LG is still not listed as one of the brands of TV from the list of choices.
Simply choose any of the TV's listed and start entering the 4 digit codes on this site (or others found via Google) - one will work.
Oct 17, 2011 | LG 32LD350 32 in. LCD TV
Need 4 digit remote code for LG LV5500 led Tv to input into TIVO remote as it's not listed in the TIVO library
Hello
Just do a code search process, and see whether it can help you. As there is no codes listed for LG with Tivo remote, this is the only thing to get it. If this does not help you to get any code, there is no other way than buying an other universal remote, which has codes listed for LG.
Code search process
OK.
Oct 08, 2011 | Televison & Video
Sky Code for LG50PS3000 Sky+ remote version 4
Go to http://sky.uebv.com and enter:
1. Your Sky+ Remote version (Inside the battery compartment)
2. Your TV Manufacturer
3. Your TV Model
Click on <GET MY CODE> and hope.
Got an answer of 1293 for LG Model 37LH3000 but not tried it yet.
Jan 06, 2010 | Televison & Video
Dec 24, 2009 | LG 37LH30 37 in. LCD HDTV
Need sky remote code for 37lh3000 lg tv please
Dec 06, 2009 | LG 42LG30 42 in. LCD HDTV
LG 42LG30 42 in. LCD HDTV Logo
35 people viewed this question
