Question about Bose Audio Players & Recorders
I have just purchased a Yamaha rx-v371 receiver. I need to know if my Bose am5 speakers would be compatible with this amp.
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
SOURCE: compatable receiver list for Bose 901 series VI
I contacted the Customer support folks at Bose. Here is what they said: With a stereo receiver, the equalizer is run through the tape monitor section in the back of the receiver. The receiver's tape monitor output, left and right, runs to the amp input section of the equalizer, left and right. Then the amp output section of the equalizer, left and right, runs to the receiver's tape monitor input section. With a surround sound, home theater, type of receiver, the theory is the same, but the connection is through the preamp-out/ main amp-in section of the receiver. Not all receivers have this feature. Most, in fact, do not. Check the back of the receiver. There would be a connection made by two U-shaped clips. The plugs would be pulled out. Then connect from the preamp-out to the equalizer's amp input section; and from the equalizer's amp output section to the main amp-in. This effectively isolates the equalizer so that it is not affecting the other speakers in the system or the receiver's surround processing. Attached is a current list of known 901-home theater compatible receivers:
Note: Specifications subject to change without notice. Bose Corporation is not responsible for any inaccuracies due to manufacturer changes. Inclusion in this list does not indicate an endorsement by Bose Corporation. When in doubt contact the manufacturer of the equipment.
I have the list in a pdf document but do not see a way to attach it.
Contact me at danmc@uwyo.edu and I'll forward the pdf.
1-30-2009
Posted on Jan 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: Can I hookup a Bose 901 EQ to my receiver and amp?
Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
Put that old amp back to work.
This is exactly how mine are connected.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Posted on Dec 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: bose speaker connection
The Bose systems are SYSTEMS for a very good reason. They're made for people who want good sound but don't want to manipulate the hardware much. The speakers and amps are designed for each other ONLY, not only electrically but through soundshaping to provide the smooth final result. The design is for you to feed the electronics a Line Level source and the magic and distribution happens internally. These are NOT mix 'n' match components. The special connectors are a clue. The Yamaha will probably blow them up if you manage to succeed with your plan.
Posted on Dec 28, 2009
TvInstall
  • 6 Answers
SOURCE: No bass response
Seems there are 2 underlying problems-
no am/fm? are antennas connected? is there static active on any station tuned to?
in terms of low bass response- double check settings both in the receiver and also on the sub itself if any available.
Posted on Jan 16, 2010
Yamaha Receiver RX-V371 broken speaker wiring connection on the back, what are different solutions?
That unit give you the option for a second set of speakers ?
If so , connect to Output 2 ( or B) on the speakers connections and select Spkr 2 ( or B) from the front panel
Dec 16, 2014 | Yamaha Audio Players & Recorders
I have a yamaha receiver rx-v371 the speaker imput clamps on the back are broken. Can i use banana plugs?
For the main speakers , Yes, you can use banana plugs. Theyre built for that.
I hope that helps
How to use Bose Acoustimass 5 speakers with new 5.1 receiver
Receiver Front L& R speaker sockets connect to Bose L& R IN.
AM5 satellite speakers connect to Bose Front L& R OUT
Set AV receiver to that Front L&R are LARGE
That's it. Then run the AV Receiver's set-up mic wizard if it has it.
Aug 27, 2014 | Audio Players & Recorders
Yamaha rx-v371 shuts off 2 secs after turning on
Return unit to place of purchase, this is clearly a manufacture defect. The warranty will cover full replacement, do not allow them to attempt repair on the current item because you will be back and forth until warranty runs out.
Apr 02, 2012 | Audio Players & Recorders
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
Aug 19, 2009 | Bose 901 VI Main / Stereo Speaker
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
