SHARP FAX FO-50 PERSISTS IN REPORTING PROTOCOL MONITOR
  • 2072 Answers
SOURCE: Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Posted on Jan 10, 2008
leroyal
  • 2120 Answers
SOURCE: Need to print out a fax transmission report from
Not possible, only the last 50 transactions are stored...only fax numbers
Posted on Feb 24, 2009
POCBM
  • 121 Answers
SOURCE: Sharp Fax - Change outgoing name/number - HELP!
Try this:
http://www.sharpusa.com/files/fax_man_FO_DC500_600.pdf
Hope it helps
Posted on Mar 14, 2009
  • 48 Answers
SOURCE: sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Posted on May 25, 2009
  • 48 Answers
SOURCE: Sharp FO-4650 fax machine
You have a bad printhead unit(laser unit) only if the problem persist. The polygon mirror is not rotating within a specific amount of time.
How do I turn off protocol monitor on sharp fax model fo-235
Had exact same problem on UX 177. You need to clear the memory. On the UX 177 unplug machine, press and hold down the COPY button then press and hold down the STOP button. Keeping these two buttons pressed plug machine in. It should display message "clear memory ?" let go of the COPY and STOP buttons and press the START button. Will then display message "memory cleared". This will also wipe out all other programming but it is the only way to stop protocol report. Then reprogram all your settings.
That stopped protocol report printing after each fax. On some machines it may be the stop and start button the need to be held down on startup. It also seems to make a difference which button you push first even though machine is unplugged.
This problem returns after a power failure so if you have a lot of numbers programmed in you might want to get an inexpensive uninterruptible power supply or plug fax into UPS for computer if you have one.
Mar 03, 2011 | Sharp Office Equipment & Supplies
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
MANUAL SHARP FO-50 FAX/PHONE
my sharp fo-5o donnot what evrytime cover ope???
Jul 05, 2009 | Sharp Office Equipment & Supplies
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Feb 10, 2009 | Sharp FO 4450 Laser Fax
Sharp fax model fo 2950m
Jan 28, 2009 | Sharp FO 2950M Plain Paper Laser Fax
Sharp FO DC535 fax will not come to ready
Turn on the fax while holding down the stop a start key, don't let go until you see 1 =all ,2=image , 3=none. Press 2 for image. If the problem persist press 1 for all.
Dec 29, 2008 | Sharp FO-DC535 Fax
Drum cost
The price should be in the $50 range.
Here is a web site to compare
http://www.bizrate.com/faxmachines/products__keyword--sharp+fo+4450.html
Mar 13, 2008 | Sharp FO 4450 Laser Fax
Sharp FO-4450 errors when sending to Brother Intellifax 475-0E
Tell me more. What model Brother? Did you call them and make sure the Brother is set to auto receive?
Aug 09, 2007 | Sharp FO 4450 Laser Fax
16 people viewed this question
jasbo
jasbo
