Using a Soljet Roland SC545EX We cleaned the heads several times but are still receiving "tiger-stripes" in the yellow. We have printed test samples and not seen this - So we go ahead and print the 19' sign and get the stripes ( 3xs) We have tried on each setting however the problem does not go away These stripes occur approx every 4" apart. What can we do to eliminate this?
  • SignBizUSA May 05, 2009
    the same problem with stripes just started and my yellow is not bright slight tint of green.
SOURCE: my canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Posted on Oct 27, 2007
  • 3 Answers
SOURCE: Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
Posted on May 26, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Posted on Jul 08, 2008
  • 14 Answers
SOURCE: Epson Artison 800 Poor Print Quality
it sounds like you have clogged the head if you leave it for 6 hours then the ink will dry inside the head then you have a big prob if i were you i would take it back to the shop and get a refund or a replacement one i have an epson dx4400 very good
Posted on Mar 21, 2009
epsinopin
  • 9 Answers
SOURCE: epson 9600 print head missing numerous nozzels
You willl probably need to clean the Pump Cap Assy.
You will need a strong flashlight/clip-on lamp to see what you are doing up in the area you are cleaning.
Move the print head to the left side of 9600. (If you need help with this let me know.)
Use a foam tipped swab slightly dampened with warm water to GENTLY wipe around the seal area of the Pump Cap Assy.
DO NOT USE A COTTON TIPPED SWAB !!!
Dip, Blot, & Wipe. Clean the Foam Swab often to wash off the residue it will pick up. Remenber to keep the swab slightly moist - not dripping wet.
If this does't help, it generally means that the Print Head is also very clogged with gummy/dried ink.
The Print Head cannot be cleaned without removing the Right Side Cover & then removing the Pump Cap Assy. This removing and cleaning is about a 1.5hr-2hr job for an experienced tech. Anyone with moderate mechanical skills can do it though.
Pump Cap Assy cleaning is usually done BEFORE replacing the Print Head.
If the Print Head cleaning doesn't work then a New Print Head is in order.
Hope this helps ! Good Luck !
Posted on Sep 25, 2009
For the roland SJ-740, the yellow and black heads are completely missed from the test print, what should we do to fix this problem?
Ahmed?
Are the cartridge heads dirty, or clogged with old dry ink?
You may clean dried ink by using a lint-free cloth that is wet.
If you do that, make sure the cartridge head is dry before re-inserting it in the right place.
Good luck.
Dec 02, 2016 | Office Equipment & Supplies
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
I am seeing verticle lines in photes I print out. Even after I clean and align. When I print the alignment test the cayan seems to have lines...
You need to clean your printer heads with a deep cleaning. Possibly more than one time. Usually the lines are caused by dried up ink in one of your cartridges. Do a test sample of print using small samples of colours and print in the top quality. If the lines still are there you need to replace one of the cartridges. You can, you know buy these very inexpensively online.I have a canon printer and I pay on average less than four dollars each.Anyway, try my suggestion as I have had exactly the same problem and if you still see the stripes let me know
Jan 25, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Jan 08, 2010 | Office Equipment & Supplies
Prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Apr 28, 2009 | Office Equipment & Supplies
Colorip machines to run on Versaworks
what rip software can I use on a roland sc-500? jimrothfuss@gmail.com
Nov 16, 2008 | Office Equipment & Supplies
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Yellow Ink Won't Print
what is the yellow ink cartrage level is it empty
Jan 08, 2008 | Epson Stylus CX3810 All-In-One InkJet...
254 people viewed this question
k24674
jasbo
jasbo
