Question about Chevrolet Vehicle Parts & Accessories
I am trying to do new insulation on my car, I need wiring diagram with engine control board which can control 5.7L engine. Chevrolet engine number GM57L6SGI 5.7 L Engine where I get to buy .
I need control board and wriing diagram for engine GM57L6SGI 5.7 L i need to buy.
  • 78 Answers
Auto-Zone has wiring diagrams online for you to see for free.
Posted on Mar 21, 2015
    Sergeant:
  • 462 Answers
Try auto salvage yard or dealer
Posted on Mar 02, 2015
Diagram 1998 Chevy metro lsi fuse box
Debbie, there are 3 fuse clusters. 2 under the hood on the drivers side and one under the drivers side dash board tucked up high on the left. Links to diagram below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.autofuseboxdiagram.com/4877-1998-chevrolet-metro-3-cylinder-engine-fuse-box-diagram
1998 Chevrolet Metro 3 cylinder Engine Fuse Box Diagram Circuit Wiring...
fuse boxes
Feb 28, 2016 | Cars & Trucks
Where can I get the wiring diagram of EVAP vent valve/solenoid circuit or the AC Delco e83 ECM pinouts?
www.bbbind.com/ free wiring diagrams . click on technical information .then five box will pop up ,click on tsb's an wiring diagrams .Next page go to the bottom of page a click I agree . On the next page click on wiring diagrams an enter your vehicle info . under system click engine , subsystem engine controls . Then click on the blue links an check out your diagrams .
Nov 26, 2015 | 2009 Chevrolet Aveo
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
2003 TRACTOR 4X4 WAGON IS MIS FIRING ON CYLINDER TWO
Try to see if you can get view the are where the plugs are firing in the dark. Check for arcing off the plug or wires to the metal engine parts. I fought with a vehicle for days trying to determine a misfire problem on a car that we just put new plugs, wires, and coils on. Turns out the ceramic insulator on one of the BRAND NEW plugs had a hairline crack down the length of the insulator. You could not see if with the naked eye, but you could feel it if you ran your finger over it. Easiest to find if you can run the engine in a dark garage.
Nov 24, 2012 | Chevrolet Tracker Cars & Trucks
95 chevy pick up 5,7L . have spark, have fuel, won't start?
how much feul pressure, it must maintain a certain amount if injected, or throtle body, try priming it ,and see if it helps, ( poor a little into inlet ) and check it , if it starts you need to check pump, or maybe just filter
Nov 17, 2012 | 1995 Chevrolet Suburban
Where is the cruise control fuse in a 2004 chevy trailblazer?
Gotta tell you, this question had me a little confused. Below are 2 wiring diagrams for you. One is for the cruise control circuit and the other is for the air conditioning circuit. The reason I gave you those is because it seems according to the wiring diagram in the cruise control that the fuse for the cruise control goes to the HVAC (air conditioning). According to the wiring diagram for the A/C yes that fuse also controls the ignition power for the A/C controller. In any case the fuse that would cover the cruise control is the number 30 fuse in the fuse panel located under the hood of the vehicle. Below is a picture of the location of the fuse panel and also fuse layout diagrams for the 6 cylinder and 8 cylinder engine vehicles as they have different layouts depending on the engine size. I hope this helps you and good luck.
Jun 10, 2011 | 2004 Chevrolet TrailBlazer
Misfire on plug #6 probably fouled..need diagram to tell me where #6 is.
Believe it or not you don't need a diagram. Your car (if of recent vintage) should have a ignition control module on top which is mounted a series of coils with spark plug wires attached thereto.
You can find the coils under the hood, passenger side, front engine area, front side of alternator, end of valve cover, mounted on brace.
On the topside, you'll numbers embossed onto the plastic. Go to number 6 (Six) and trace that wire to your number six plug.
Improve the Fixya.com experience for everyone by voting!
All the best
Ben
Jun 03, 2011 | Chevrolet Tahoe Cars & Trucks
I need a spark plug wire diagram for 1987 ford 302 crown vic
1987 Ford Crown Victoria 5.0L FI 8cyl
Duraspark Type Plug Wires
The spark plug wires used with the Duraspark type ignition system are 5 / 16 in. (8mm) in diameter to contain the higher output voltage. There are two types of wires used in this system, and some engines may have both types installed. It is important to properly identify the type of wire used for each cylinder before replacements are made.
Both types are blue in color and have silicone jacketing. The insulation material underneath the jacketing on some plug wires is a silicone layer separated by glass braid. The plug cable not incorporating the silicone layer is used where engine temperatures are cooler and are identified with the letter SE with black printing. The plug cables with the silicone insulation are used where high engine temperatures are present. These cables are identified with the letters SS with white printing.
Each spark plug cable, if original, is marked with the cylinder number, model year and date of cable manufacture (quarter and year). Service replacement wires will not have cylinder numbers, or manufacture date.
On any vehicle equipped with a catalytic converter, never allow the engine to run for more than 30 seconds with a spark plug wire disconnected. Unburned fuel in the cylinder may ignite in the converter as it is exhausted and damage the converter.
When removing spark plug wires, mark and tag the individual wires. Grasp, then slowly, twist the insulator back and forth on the spark plug to free the insulator. Do not pull on the wire directly as it may become separated from the connector inside the insulator. Special tools are available which can help ease plug wire removal, and prevent damage to a cable.
When installing a new set of spark plug wires, replace the wires one at a time so there will be no confusion. Start by replacing the longest wire first. Route the wire exactly the same as the original.
Fig. 1: 6 cylinder engine-240Firing Order: 1-5-3-6-2-4Distributor Rotation: Clockwise
Fig. 2: 8 cylinder engine-255, 302, 351, 400Firing Order: 1-5-4-2-6-3-7-8Distributor Rotation: Counterclockwise
Fig. 3: 8 cylinder engine-390, 427, 429, 460Firing Order: 1-3-7-2-6-5-4-8 DistributorRotation: Counterclockwise
Visit autozone.com (free register) for more details.
I hope helped (rememer rated this) Good luck.
Oct 15, 2009 | 1987 Ford Crown Victoria
Need a diagram for fan belt or serpentine belt
Here is a diagram for a 5.7L Hemi, and 1 for a 5.9L diesel. Hope this helps!
9d0184e.jpg 5,7L HEMI
5.9L Diesel
Jun 06, 2009 | 2006 Dodge Ram 3500 Truck
Intec ps-2 7005-c controller
Try clicking here first. If that can't help, I would try going to sony and RMA the controller, which means you send them your controller, and then they'll send you a brand new one for free. But they may charge S and H. I couldn't find any circuit board diagrams. Sorry about that. Well, Good Luck. Please rate my solution.
Jan 08, 2008 | Sony PS2 Dual Shock 2 Controller...
Vehicle Parts & Accessories Logo
88 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
