SOURCE: Minolta Konica 7145 error code 26-3
NOT SURE BUT YOU CAN GET SERVICE MANUAL WITH ERROR CODES DEFINITIONS www.precisionroller.com type in your model
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of
the 220V. Immediately the malfunction code (error code) of "C05"
appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found
the "Trouble Reset Switch" (not shown in the user manual) by opening
the upper back panel and pressing the small black button in the lower
right hand corner of the middle circuit board (green).
It worked perfectly!
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
SOURCE: konica minolta Bizhub C6500 error code 2424
http://onyxweb.mykonicaminolta.com/ocp~eng/sso.asp
try knowledgebase
