Question about GE GTWN5050MWS Washer
How to check lid switch on GE gtwn5050mws washer
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: GE washer doesn't spin or agitate has new timer
Bad motor?
Posted on Apr 15, 2009
  • 326 Answers
SOURCE: Washer will agitate but will not spin, could it ge lid switch ??
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 06, 2009
SOURCE: GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Posted on Jan 16, 2010
  • 31 Answers
SOURCE: how to test bad and good lid switch for washer ge top lpad
Yes the switch is bad.
Posted on Nov 29, 2011
Push start and fill button just beeps and blinks.
after making sure switch is clean then follow your users manual , if you don't have one you can download from web .
Dec 07, 2015 | GE GTWN5050MWS Washer
GE GTWN5050M0WS top loader Washer, during the spin cycle the tub itself will not spin, but the bottom center piece will? Any ideas? Thanks
Call in an engineer. We had the same trouble and it was the clutch in the bottom of the drum. Takes about 20 minutes to fix.
Sep 18, 2015 | GE GTWN5050MWS 27" top-load washer with...
Remove washing machine knob
You need Washing machine Engineer
Mar 15, 2015 | GE GTWN5050MWS Washer
Won't spin after wash cycle
Bad timer or reversing switch
Jul 30, 2014 | GE GTWN5050MWS Washer
Why doesn't my washer drain?
Sounds like your pump is out.
Jul 13, 2014 | GE GTWN5050MWS Washer
Does not start when start button pushed
The machine only agitate but won't spin. Anybody can help here.
How to test run the motor.
Sep 12, 2013 | GE GTWN5050MWS Washer
GE GTWN5050MWS makes noise washing
If you have oil spots on laundry that you washed, then the seals are bad on the transmission and drive spline
Oct 14, 2012 | GE GTWN5050MWS Washer
Washer wont start
You need to check the lid switch, you can test it's function with a multimeter to see if it is working correctly or not.
Mar 12, 2012 | GE GTWN5050MWS Washer
My washer will not agitate after filling with water...
is the lid closed? if it is the it is the lid close safety switch you can by pass the switch but i would replace it if u do bypass unplug the machine its a safety thing. Tom
Jun 29, 2009 | GE WBSR3140DW Top Load Washer
GE GTWN5050MWS Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
