Question about Pentax Optio Z10 Digital Camera
I have a pentax optio z10. when i turn it on (slide the front open) it says "green mode" then proceeds to turn blank..
  • 3 more comments
  • wbarty6539 Feb 21, 2009
    I have the same problem. when it turns on, the screen has green mode at bottom left corner and in the center it has AUTO PICT auto picture it will stay on for a few seconds and then turn off.
  • Anonymous Mar 30, 2009
    i turn my z10 on, it displays a picture of the pet and says green mode. then it shuts off
  • faustfam2 Apr 09, 2009
    Auto Pict comes on with "green mode" icon and stays on for about 3 seconde then everything goes off.
  • bedrockjon May 07, 2009
    when I turn on my optio Z10 it says green mode & auto pic on screen, that's it, won't do anything else,
    if I turn it off slide cover, it stays on, I have to remove battery to turn it off, or sometimes it will eventually turn off,
    if I hold arrow button then turn on it will show last pic taken, but do nothing else,
    If I hold down OK button it will show clock but do nothing else,
    if I hold munu button & open it says ver 1.00 then goes to auto pic screen & does nothing else,
    with all these it will not turn off for a while , with slider closed,,
  • Anonymous May 23, 2009
    how do i hook it up to the computer the cords not working
I got the same problem. try holding the play button and turning on. it wont help fully, but i was able to look at my already takin pics
Posted on Mar 30, 2009
How do i remove green mode on a camera pentax RS1000
Pentax Optio RS1000 Digital Camera Green - Questions ...
www.fixya.com > ... > Optio > Pentax Optio RS1000 Digital Camera
turn green mode off my camera how to turn offf green mode just hit the green button, its the delete pic button as well, but it can be used to turn green mode on ...
Oct 27, 2015 | Pentax Cameras
The sd card in my optio z10 says it's locked. How do I unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 07, 2010 | Pentax Optio Z10 Digital Camera
What is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
Jan 29, 2010 | Pentax Optio Z10 Digital Camera
Me kids have played with my camera and set the green mode.if i push the menu button it tells me that the green mode needs to be canceled touse this function
You may need to look up how to reset your camera to factory settings. Look that up in the manual. You will not loose any pictures.
Hope this helps.
Jan 05, 2010 | Pentax Optio Z10 Digital Camera
Optio Z10 is stuck on green mode, how do i fix it?
Go into the menu and find "reset"...follow the on-screen instructions.
Dec 10, 2009 | Pentax Optio Z10 Digital Camera
On my PENTAX Optio Z10, the slide shutter cover came loose, it slides left and right to open and close. I didn't lose any parts but I can't slide it back on. I currently have a rubber band holding it...
Heres where your going to have to compromise or try to reach the company to see if they will repair it. Is it essentiel to you to have the factory cover? If not you could most likely make a cover out of shrink wrap or aluminum foil or you could put you camera in a bag
Aug 05, 2009 | Pentax Optio Z10 Digital Camera
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Jun 10, 2009 | Pentax Optio Z10 Digital Camera
Pentax Optio Z10 Digital Camera Logo
456 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
