Question about Zanussi Ovens
How to install a zanussi ZOP37902BK
How to open the connection box on the oven
2 Suggested Answers
SOURCE: Installing a Zanussi ZBF260 oven
i turned of the power in kitchen when i was away for a few weeks, and now i need to get the oven working again.
Posted on Aug 21, 2008
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Dado
Sep 10, 2014 | Zanussi Ovens
How to wire up a zanussi zop37902 oven
You will need to have an electrician connect the oven to your power system in your home, unless you are expert at doing this yourself. ZOP37902XK Ovens Zanussi Products Cooking
Jun 07, 2014 | Zanussi Ovens
Fuse
According to the Manual, section about Electrical Connection Pg14 is that there is no fuse as it is connected to the buildings main fuse box via a double pole switch between oven and the mains electricity.
UserGuide\Manual
Oven Diagrams
May 02, 2013 | Zanussi ZBF260 Electric Single Oven
I want to change the light bulb in the oven,.Mod.no.ZDQ695A can you help me.
I will assume that the ZDQ695 bulb replacement procedure is the same as that for the ZDQ695A. The ZDQ695 uses a 25 W appliance light bulb (300 C). Unplug the appliance before starting. Open the oven and remove the racks for space to work. Insert a flat blade screwdriver between the side of the oven and the glass cover above the bulb. With your hand support the cover and pry it away from the wall of the oven until it releases. Push the top of the cover towards the oven wall and use your fingers to pry the bottom of the cover away from the housing. Then remove the cover. Unscrew the old bulb (counterclockwise) and then remove the bulb. Then screw in the new bulb. Replace the glass cover (position the flange so that it is pointing to the back of the oven) by pushing it into the hole to cover the bulb assembly. Replace the shelves and close the oven door before plugging the oven back in.
Zanussi manuals are available here: http://www.zanussi.co.uk/en-gb/Support/Manuals/ . Enter the model number in the search box. Alternatively, the manual for the ZDQ695 is available here: http://kitchen.manualsonline.com/manuals/mfg/zanussi/zdq_695.html . Click on the Get This Manual button.
I hope this helps.
Jul 24, 2011 | Zanussi ZDQ695 Electric Double Oven
The element has blown on my Zanussi ZBF860 oven. I
You should be able to remove the element without removing the oven. Open the door and remove the back panel, normally 4 screws. This will expose the element. Then it should be 3 or so screws holding the element to the frame, remove these and slowly pull the element towards you carefully, then remove the 2 wires from behind and make sure they don't fall back into the oven as you will need to remove the back panel to get them. Then reverse process to install new element. Hope this helps.
Mar 15, 2011 | Zanussi ZBF360 Electric Single Oven
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
Why does the light stay on even though the switch is in the off position on my cooker isolation box?
It sounds like the isolation switch is faulty, which can happen, or it it could be connected incorrectly.
I would advise having the switch checked.
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
Oven connection
I have tried to locate electrical information on your oven from here in the USA. I was not able to locate the electrical requirements for your Zanussi ZOD 330X. If it is typical voltage for ovens like ours in the USA I would say no and that the power should be 240 volts and 50 ampere breaker. But to be sure you should locate a local supplier for your model and ask them first. This will prevent any incorrect answers from someone that is not familiar with your local requirements. Thank You, Sea Breeze
Mar 25, 2009 | Zanussi ZBF360X Electric Single Oven
I've got the same issue, looking at them it's either the blue or yellow ones you want, the manual states that it should be installed with 2.5mm flex cable if going to a plug and 2.5mm twin and earth cable if your going to an electrical outlet.
Mar 07, 2008 | Zanussi ZBF260 Electric Single Oven
Ovens Logo
145 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
