What is the weight of a Phillips slc431eab
What is the correct wall bracket
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: I have a Phillips flat screen tv model number, 42pfl7603d/10. The stand at the base of the tv that it sits on has broke, my walls won't support wall brackets. I need to know where I can order a ne
About the only hope here is Philips or even EBAY.
Posted on Dec 06, 2012
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
http://laundry.manualsonline.com/manuals/mfg/whitewestinghouse/whitewestinghouse_dryer.html?p=7
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
What is the weight of the Samsung LA40S71BX
Tried to find the info for you. suggestion is to make the barcket to hold 50 lbs.
Dec 21, 2014 | Samsung Televison & Video
Where can iget a wall bracket for t.v. phillips SB009630 ?
Contact the authorized dealer for Philips. They can help you. Electro help
Sep 10, 2014 | Televison & Video
How can I put. On my led tv on the wall
You need to purchase a wall bracket for your TV. There are several types on the market. Make sure the mountind holes on the TV line up with the wall bracket mounting holes and it can support the weight of your TV.
Google search for a wall mounting bracket for your model TV.
Nov 21, 2011 | Televison & Video
Can a sony bravia kdl-w40a12u be put on a wall thanks
You need to use GOOD WALL BRACKETS which can hold the weight of the TV.
Also the mounting on the wall must be firm with good foundation tower bolts.
please check on the links below for some tips and ideas on wall brackets.:
TV Wall brackets: http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
Jul 28, 2011 | Sony KDL-W40A12U 40 in. LCD Television
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
What is the weight of model TX-42F430S Television. I am mounting it on the wall. Thank You!
I found 2 different sources online that list the weight as either 61.1 lbs or 68.1 lbs. I think the 61.1 is more accurate for the bare TV without the stand or anything attached. But keep in mind that when mounting a flat panel TV to a wall, you should secure it with hardware rated for much higher weight tolerances. Many mounting brackets for TVs of this size are rated for 150 - 200 lbs, and for good reason. Consider a situation where someone trips and catches his balance on the wall-mounted TV. The TV is already putting 61 lbs of pressure on the bracket, so any force from any other contact is added to that. It doesn't take much to add up to 100 lbs or more. If the mount breaks free from the wall, you'll have damage to the TV, the wall, the mount, and any furniture or flooring beneath the TV, so the best advice is to mount it as if it weighed about 150 lbs. The 7 lbs +/- difference in reported weights won't matter at all.
Jan 25, 2011 | Westinghouse Televison & Video
How do you install an over the range micro-wave, i can't seem to figure out how to insert the micro wave onto the bracket on the wall.I'm having trouble with the clearance from the cabinets above .
Use the template that came with the microwave to insure proper height of the wall bracket. If height is correct and you have drilled the three holes in the top cabinet, (one for power cord two for mounting bolts), the unit must be tipped forward (front lower than back) so the bottom can be hooked to the wall bracket. Once hooked, start the power cord throught he hole into the upper cabinet and the unit can be tilted upward to allow you to start the bolts that support the front of the unit. It is nice to have help with the weight of the microwave. If attempting alone, make sure that everything is within reach when you start and if possible pull the range and move it aside. Good luck.
Aug 25, 2009 | Magic Chef Kitchen Ranges
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
