Question about Canon imageRUNNER 8500 Copier
Canon iR105 with Error E000220-0000 - Canon imageRUNNER 8500 Copier
2 Suggested Answers
  • 39 Answers
SOURCE: i found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
Posted on Dec 18, 2009
Ir105 canon model error code E000068-0000
Hi Mohammad.
There is an error in the high-voltage output to the separation charging assembly.
An error (leakage) to the high-voltage output to the separation charging assembly is detected.
Check if the transfer charging assembly and separation charging assembly are mounted properly. - Check if the connector (J722, J723, J730, J734) of the HV-DC PCB and the connector (J741, J742) of the HV-AC PCB are mounted properly. - Replace the HV-AC PCB. - Replace the separation charging assembly. - Replace the pre-transfer charging assembly. Canon iR105 Error Codes List page 3 from 9
Aug 15, 2016 | Canon Imagerunner Ir 105 Copier Printer...
105 model cannon error code E000068-0000
I've already answered this, please don't keep posting your question, it doesn't help us to help you. Canon iR105 Error Codes List page 3 from 9
Aug 15, 2016 | Canon Office Equipment & Supplies
Error code E000068-0000
This is the third posting of this question from you. Please don't do this in future. Canon iR105 Error Codes List page 3 from 9
Aug 15, 2016 | Office Equipment & Supplies
Canon 105 error code E 000220-0000
Here is the information I found online explaining the error code above:
http://www.copytechnet.com/forums/canon/5926-canon-ir105-error-e000222-0000-a.html
Jul 21, 2016 | Canon Office Equipment & Supplies
I have canon ir105 gives an error code e240
hi the Main cause Condition The main controller PCB is faulty. The DC controller PCB is faulty. The wiring is faulty (short circuit, open circuit).
Mar 22, 2016 | Canon Office Equipment & Supplies
Hi every one.i have canon copier ir105 gives me error code e602-102. I replaced hard disk ,after that the machine gives me error code e000744-2000 please if any help thank you
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
Nov 21, 2010 | Canon imageRUNNER 105 Copier
I found error in canon ir7105, and i checked
Dec 14, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 8500 Copier Logo
285 people viewed this question
old marine
old marine
