Question about Toshiba Satellite M45-S169 Notebook
MICROPHONE IN THE LOGITECH CAM NOT WORKING
WE CAN HERE PEOPLE SPEAKING TO US ON MSN BUT THEY CAN NOT HEAR US FROM THE MICROPHONE IN THE LOGITECH CAM
  • mursa Jan 13, 2009
    YES
  • Bill Speer
    Bill Speer May 11, 2010
    Have you used the wizard to setup the microphone already?
  • 565 Answers
Use the wizard in msn and also look sound options maybe the mic is muted. u can try does the mic work or not in sound recorder proram under start menu, the software for logitech u can find from www.logitech.com under support
Posted on Jan 13, 2009
  • Teet Bergmann Jan 13, 2009
    if it helped rate fixya
I bought last month an acer aspire 7715z. On the first times when I spoke on skype or msn all was perfect, one could hear me speaking, but recently my interlocutors cannot any more hear me.I have window 7,...
Hi, your webcam should have a microphone built in, Please make sure on the webcam setting that it is not disabled.
The Microphone is next to the cam.
I hope this helps.
Regards - Anthony
Feb 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
MY Logitech quickcam notebook
You may have to into the MSN Video and Audio Configuration utility and make it use the mic built into the webcam. It may be looking for audio input from another source, if this is the case, it won't work from the Cam itself.
Jun 20, 2009 | Logitech QuickCam Connect Webcam
Logitech QuickCam Communicate STX web cam
hi
open up this page and start the remote support session so we can figure it ou ttogether
http://www.fastsupport.com/772273404
if you have any problems with the page use the manually download software link on the page
Dec 30, 2008 | Logitech QuickCam Communicate STX Personal...
Acer Extensa Web Cam sound system
Hey,
Check your microphone settings, or use another microphone to solve the problem. Like this one, CLICK HERE EBAY LINK
Thanks,
Ekse
Aug 29, 2008 | Logitech QuickCam Pro 5000 Webcam
Video sound problem
Durring video conferencing with MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? trnsp.gif Answer This article applies to the following products:
All Logitech Web Cameras with MSN Messenger Support
This article applies to the following software:
Windows XP
Test the Microphone in Sound Recorder
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
If the microphone does not work in Sound Recorder, click here for help in determining the problem with the mic.
While using MSN Messenger it is the messenger program, not the camera software, that negotiates the audio streams between two MSN Messenger Clients. Although we cannot directly support audio issues in MSN Messenger, the following steps have been known to resolve and improve audio issues in MSN Messenger. For further information, please consult the help documents associated with MSN Messenger.
Test Your Networking Router
You can also test to see if your router is causing audio issues by either physically bypassing your router and connecting directly to your cable/DSL modem or by setting up your computer as the DMZ (de-militarized zone). If you are a novice networking user, it is not recommended that you leave your computer in the DMZ state for extended period as that may leave your computer vulnerable to attack. However, you may briefly configure your computer as the DMZ to determine if your network settings are causing the audio issues. For DMZ setup instructions, please consult your router's documentation.
Enable Universal Plug and Play (UPnP) on both Windows XP and Your Router.
If either of the above steps resolves the no audio problem, try the following steps.
  1. Open Add or Remove Programs in Control Panel. To open Add or Remove Programs, click Start, point to Settings, click Control Panel, and then double-click Add or Remove Programs.
  2. Click Add/Remove Windows Components.
  3. In the Components list, select the Networking Services check box, and then click Details.
  4. Make sure the Universal Plug and Play box is checked.
Notes: If you used a CD to set up Windows, you will be prompted to insert it into your computer.
If your router does not support UPnP or you still get no audio after enabling UPnP on both Windows XP and your router, you must manually open all UDP ports between 5004 and 65535. This is because the audio streams are sent dynamically using that range of ports. Without a dynamic way to open those ports like UPnP, there is no way for MSN Messenger to successfully negotiate the audio stream. Consult your router's documentation for instructions to manually open these required ports.
If you are still experiencing audio issues within MSN Messenger, and you have verified that the microphone is working in Sound Recorder, contact MSN Messenger Support.
This article covers Accoustic Echo Canncellation (AEC) and how it works.
QuickCam 10.x and RightSound supported cameras
QuickCam 11.x and RightSound supported cameras
Call Central and RightSound support audio devices
This article applies to the following platforms:
Windows® 2000 Professional
Windows® XP Professional
Windows® XP Home
Windows® Media Center Home
Windows® Vista
Accoustic EchoCancellation (AEC)'s purpose is to prevent sounds from your computer's speakers to be picked up by your microphone. This can be a significant problem with audio or video calling applications where the voices or sounds from other parties of the call is being inadvertently picked up by the microphone and fed back into the call, creating echo and other sound distortions. Without AEC, this echo can detract from the quality of a call and in extreme situations, the echo can degrade the audio experience to the point where the audio is useless.
To prevent this from happening, the AEC component monitors sounds being played by your computer's speakers while monitoring the incoming sound picked up by your computer's microphone. The AEC module takes the outgoing and incoming sound signals and compares them to determine if echo is present. If echo is found, it is subtracted before the audio from the microphone is sent to the requesting application. This will result in the remote party only hearing you speak, without being distracted by hearing their own voice echo back to them.
When enabled, echo is eliminated for the recipient of the audio/video message. For echo free chatting, both parties need to have a RightSound technology enabled web camera that supports the AEC feature.
Apr 05, 2008 | Logitech Quickcam Chat Webcam
Logitech QuickCam Express: Microphone not working
If you have windows messenger follow below
Windows XP
Windows Messenger is a native Instant Messenger application to Windows XP. This application can be used to set the output device of your choice. In turn, this information will carry over to the MSN Messenger 7.5 application settings.
Launch Windows Messenger and execute the audio tuning wizard.
  1. Go to “Start”.
    Select “Run”.
    Type “msmsgs” and click “OK”.
  2. In theWindows Messenger, click “Tools” and select “Audio Tuning Wizard”.
  3. Follow the steps which are provided by the “Audio Tuning Wizard” and select your desired Microphone & Speaker device.
  4. Once this process is complete, close the Windows Messenger application.
    The configuration change made through Windows Messenger should now be set in the MSN Messenger 7.5 application.
Mar 08, 2008 | Logitech QuickCam Express Web Camera
Help
If you have MSN Messenger follow below:
Windows XP
  1. Go to “Start”.
    Select “Run”.
Mar 06, 2008 | Logitech QuickCam Express Web Camera
Logitech cam with mic
Mousy, please be more specific as to what service you're using (msn, yahoo, etc)
Dec 25, 2007 | Logitech Webcam
my logitech cam works perfectly but nobody can hear me done all the checks and it seems to be working on the checks but not when i use it
Dec 24, 2007 | Logitech Webcam
Toshiba Satellite M45-S169 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
