Question about Kenmore Elite 45986 Front Load Washer
Kenmore dishwaser clean light is flashing and will not letme start another wash. only thing that works is the drain pump but then it goes back to flashing clean
  • 15,935 Answers
Unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
My kenmore clothes washer not starting the spin cycle
Check the drain hose before it goes into the drain, if it is full of water. If you can pull the drain hose out of the drain, try to drain it into a bucket. The reason it won't go into spin cycle is that the pressure switch senses to much water in the tub.
Now this can be caused by several things, broken drive belt, bad drive motor and finally a bad pump or a clogged pump. In any caseif you need to look at these parts, disconnect the power cord 1st, then remove the back panel to view all these parts. If you think you have unplugged the pump or drained the water, then plug it in and try another wash cycle.
Is this a front loading washer?
Jan 30, 2015 | Kenmore Washing Machines
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Start/Pause light flashes, won't start. No error code. Pump or hose blockage?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jun 28, 2012 | Zanussi FJS1225W Front Load Washer
The F02 keeps flashing M#110.42832 CSM#1004028 pls help
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 09, 2011 | Kenmore HE3T Washer
Dishwasher will not start. The clean light is flashing on and off. If I push the cancel button it appears to be draining but there is no water in the tub and it just continues. When I push the start...
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Kevin
Jan 20, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
Kenmore ultra wash 665 dishwaser wont start. blinking light
The control panel is most likely defective, take it back.
Aug 22, 2017 | Kenmore Dishwashers
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Changed Electronic control on Kenmore dishwaser
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Nov 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Mar 21, 2007 | Kenmore 24 in. 17019 Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
