Question about Garden
Briggs stratton 450 series mower 145 cc engine governor fail to speed up engine to cut or works only for short time engine starts fine and idles ok
Governor fails to operate
  • 211 Answers
SOURCE: SnapperLawn Mower 8 hp Tecumseh engine runs only on high speed.
Hi
first check the governor linkage.The link with the governor sistem from crankcase is the lever(arm) with some holes.To encrease the sensitivity, raise the spring into the next higher hole in the arm.To descrease the sensitivity,hook the spring into a hole lower than its original position.If you need more info just tell me.
regards savumihai71
Posted on Dec 05, 2008
  • 376 Answers
SOURCE: Briggs and Stratton Governor Linkage problem
The easiest thing for you to do is look at any 12.5-19hp Briggs single cylinder engine that's on just about any riding mower.. They all have the same set-up.
Posted on Jun 10, 2009
Dustybobcat
  • 39 Answers
SOURCE: briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Posted on Mar 14, 2010
  • 18 Answers
SOURCE: YardMan U804H lawn tractor idles too fast
Might want to remove the blower housing and check for trash blocking governor mechanism.
Posted on Apr 18, 2010
  • 149 Answers
SOURCE: 2 springs that go on the governor and to the
The large spring goes on the loop on the link that connects the govenor and carby buterfly together, the other end goes to the metal tang that sits up and moves with the hand control this tang has a long "arm" that alows you to set the high RPM. the small one goes to the same loop but conected the other end to a tang sticking up that dosent move that is closer to the fan cowling. this one isnt critical as it only a dampener. start the engine run up at Full throtle and bend the tag to set max speed 3400RPM I hope this helps
the words are getting jumbled up as Ive been doing this for the last 2 hours...:)
Posted on Jul 02, 2010
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Why won't my Briggs & Stratton 190 cc engine stay running?
probably a carb problem if it will start but not carry on running, possibly dirt in the float bowl
Jun 10, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
How do you control idle
This sounds like a governor problem, try moving the governor back and forth,l
Apr 17, 2013 | Craftsman 675 Torque 190cc 21" Briggs ...
Briggs statton 375 starts runs very high revs how can i slow it down
remove the top cover from the engine and see if theres a nest stopping the governor from moving
Aug 20, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
Briggs & Stratton Poulon Pro 600 Series Cuts Out After a Min
Water in the carb bowl. Primer charge is gas...what the main jet draws is water! Tipping backwards lets the water move away from main jet pickup and clean fuel to enter engine.
Drain the tank. Then the carb and fuel line. Then check your gas can for watery fuel. *(dump it into a large plastic bowl and look to see if there is a layer of water on the bottom. If you shake up the fuel before you pour it off you will see cloudy liquid if there is water in it).
That should do it.
Jul 17, 2010 | Briggs & Stratton Garden
Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Apr 25, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Apr 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
20 hp briggs and stratton revs up and down
lower throttle and if that doesnt solve it check the governor might be broke
Jun 24, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
