Cannot perform movie recording basing on the programmed schedule. Schedule is altered, forwarded to another year, whenever "preparing to record" appears on the screen of the TV.
42"
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Sounds like some confusion, what is signal source and provider for that.
Posted on Dec 12, 2012
  • 36 Answers
SOURCE: Bought a new 42' flat - "No Program or Weak Signal"
Hi,you have not said weather you are using a scart lead(euro connecter)or an RF lead,if you are using the later don't,please connect the vcr to the tv via the scart to scart euro connecters,use a good quality scart lead(the thicker the better)as the thicker ones generally are 21 pins connected meaning it should be auto switching so as soon as you play a tape it will come straight on.
Posted on Feb 02, 2008
SOURCE: how to record freeview programs off tv with built in freeview
I have recently purchased a TV with built in Freeview. How can record programs onto my VCR? How many scart cables do I need?
Posted on Nov 11, 2008
SOURCE: Black screen/No TV Guide
I had the same problem, LG replaced the main board to repair, Set has a two year warranty
Posted on May 25, 2008
pilot210
  • 39 Answers
SOURCE: No picture on startup and random remote cntrl functions stop working
Common problem on this set is the main board p/n AGF33761101. However, you might try a 'quick fix' mod on this set which involves locating and bypassing components.
I do think that the replacement board just have these 4 coils bypassed on them already, so you might be able to save some $$$ if you're electronics-savvy by removing and discarding coils l4010, l4011, l4012 and l4203... then jump the solder pads they were on with small bits of wire, making very sure not to short to ground. Good luck!
Posted on May 19, 2009
micromend
  • 748 Answers
SOURCE: I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Posted on Sep 24, 2009
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
Tip
Schedule the recording while record streaming music from internet
Tips on schedule the recording while record streaming music from internet
Then found a tool named streaming audio recorder. It can schedule you recording as below.
1. set the "Starting time"
2. Set the "Duration" time.
3. After recording, help you turn off the computer.
i am not sure this can help you .
it supports all popular streaming media protocols, HTTP, RTSP, MMS, MMSU, MMST, etc.
on Dec 29, 2008 | Apple Streaming Networks PMR-100 iRecord...
On A dmr.ez48v on schedule a program on the speed on how mu ch time is left at the top of screen how do you change the speed
On the remote at the bottom next to record is RECMODE this changes the speed. You will have to select each recording you want to alter to change it I think.
Oct 20, 2014 | Panasonic DMR-EZ48 Dvd/Vcr Combo Recorder...
How can I record TV on my laptop?
Step 1:
b> While TiVo and other devices allow users to record and play back their favorite TV shows and movies whenever they want, those who watch television on their laptops have been forced to rely upon a number of different Internet websites that host movies and television shows. Fortunately, hardware and software now exists that allows laptop users to record TV shows directly onto their laptops and replay them whenever they like. All they need is an open USB port.
Connect the USB TV tuner to the laptop using a free USB port. Connect the cable wire to the USB tuner's cable input. Insert the TV tuner's installation disk into the laptop and follow the on screen directions to install the appropriate drivers and software. When prompted by Windows, select "install software automatically" to install the device drives. When prompted by the WinTV software to choose which programs to install, ensure that the option for the WinTV scheduler is checked. Launch the WinTV 2000 software now installed on the laptop. Press the "scan" button to load all of the available television channels. The channels that the tuner is able to locate will be displayed in the bottom half of the screen. Press "close" when the scan is complete. The amount of time to complete this step will vary depending on the number of channels being added. Choose a channel to record using the channel selection buttons on the left hand side of the on screen menu now displayed. Press the "record" button located on the bottom of the screen to record the program current displayed on the screen. Alternatively, recording can be scheduled using the WinTV Scheduler software included in the WinTV installation package. From the WinTV Scheduler main window, press "add program". Next, enter the time and date in addition to the channel to be recorded. Finally, click "save program". While recording TV on the laptop is not nearly as straightforward as it is with Tivo and other similar devices, the above methods are both reliable and relatively intuitive.
b>
Feb 15, 2013 | Computers & Internet
Every program scheduled to record starts and ends five minutes early? So the end of the preceding program is recorded and the end of the selected program is cut off.
BigBillO,
One of the options for the DVR recordings is starting and ending before the program starts and ends. You can change this setting to your preference. To change , press the DVR button 2 times on your DISH remote. This will bring up the "My Recordings" screen on your TV. Go to "Schedule" button on the right side of the screen. Press select. You should be on the "Daily Schedule" screen. Go to "Timers" button on the right of the screen. Press select. You are now on the "Timers List" screen. Select one of the programs scheduled to be recorded and press "Select". You are now on the "Timer Schedule" screen. Go to "Options" button and press select. You are now on the "Timer Options" screen. This is the screen you can set your preference for the "start early" and "stop late" settings. Be sure to select the "Set as System Default" if you want to apply this setting to all your recordings. I hope this helps.
Ray Calo
DISH Network
Mar 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Panasonic DMR-ES40V VCR won't schedule record: Recently, the VCR will not do scheduled recording anything beyond today. I can schedule a recording and it appears OK (I get red light on panel), but I never...
I found this solution on one of your old notes (but a different machine). I set up a scheduled record for 11:59 PM to 12:01 AM for the current day, then set up the scheduled record for the next day. The VCR recorded both the initial 2 minute session and the later one which I wanted to record.
Dec 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Accessing and recording schebuled TV video.
You were not too clear on the problem, but if you mean playback, then a very good program is PowerDVD. It will access the files stored (Pinnacle and other capture devices, store the files as .mpg typed, NOT DVD .vob files.) Software like AVS video Converter, can create the DVD formatted disks; trial is free download.
Jul 23, 2009 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
My VCR doesn't record from my Digital TV. It did before.
Your VCR does not have a digital tuner. If using an antenna or basic cable, you must decode the digital signal through the D/A converter first, then send the signal via the RF cable (Screw -on ) or Audio/Video RCA to the VCR. You will have to manually press record. My guess is that you were used to programming and leaving it. So, if you are/were using your VCR as a tuner to schedule recordings, it is no longer a valid option. If you have a cable or satellite box with a DVR, this is the way to go. I am not sure if anyone offers a VCR with a digital tuner. Google and discover. Unfortunately all those hours (years in some cases) we spent learning how to program our VCRs is now in vain.
Jun 16, 2009 | JVC SR-VS30 Mini DV/S-VHS VCR
Timer Recording
To schedule a weekly or Mon-Fri program on the DVD scroll back in the "date" box (instead of forward to a future date. You will have options for once a week or Mon-Fri.
Jul 27, 2008 | Panasonic DMR-E75V DVD Player/VCR
Possessed
Dear lost366,
The problem lies with micro IC (cpu IC) . This has to be replaced. Please contact authorised service centre.
Jun 15, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Televison & Video Logo
Top Televison & Video Experts
