Question about Canon SELPHY CP720 Printer
Canon selphy cp720 printing partial image
Prints only a partial image as though the print film is not contacting the print head, or the heater is not functioning on one side.
rmeyer
  • 80 Answers
SOURCE: canon selphy cp720
here is a link to a site that you can download the drivers. You will have to download them and save them in a file that you remember because you will need to browes for them later. After they are saved on your hard drive then you will have to install new printer. located your printer from the list. This will be a local printer most likley from a usb port. After you have indentified the printer you will need to say that you have disk. browse to the file where you saved the drivers in that file you should see the drivers file then say ok.
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
Posted on May 26, 2008
SOURCE: CANON SELPHY DS810 PRINTER PROBLEM
i am having problems changing catridge,help
Posted on May 04, 2009
  • 18 Answers
SOURCE: my canon pixma mini260 will not print full image
Make sure the settings are on A4 not A5. In the printer settings
Posted on May 05, 2009
  • 1121 Answers
SOURCE: print head, some nozzles blocked
the print head is defective and print head control board, need replacement. normaly very expensive spare parts, above printer price.
Posted on Dec 25, 2009
Only half of the picture prints on my selphy cp 730 canon printer
Nov 01, 2014 | Canon SELPHY CP730 Thermal Photo Printer
When trying to print from my mac an event warning come up stating specified ink cassette and paper not found. However, printer works when printing photos directly from camera
check the driver to be sure it is good, your computer control panel to be sure it is the designated printer and then try a virus scan...
Best regards
Ck
Mar 06, 2011 | Canon SELPHY CP720 Thermal Photo Printer
My Selphy ES40 continues to repeatedly print pictures that it has already printed, and I can't get it to stop. As soon as I turn it on it starts printing previouslyy printed pictures. I'm wasting lots of...
check in the printer icon, if any print jobs in q.
next unplug the power and remove the ink cartridges as well .. now insert the power first and then insert the ink cartridges..
this is one way of doing a semi full reset of the printer
Aug 12, 2010 | Canon SELPHY CP720 Printer
Canon Selphy C510 connected and has driver but does not print from computer file. Prints fine direct from camera......
copy all the files to the computer then unplug your camera. It will print your files from the computer. Dont forget to check your printing settings.
May 02, 2010 | Canon Selphy CP510 Thermal Photo Printer
I have lost the instructions to set up cannon
here you go mate..tehere are also drivers there http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=359&modelid=14095
www.ziggy-links.com
Dec 14, 2009 | Canon SELPHY CP720 Printer
I lost my cd and need to download the stuff to make it print
Go to CANON SELPHY CP720 support homepage.
Click on The "Drivers & Downloads" tab and then select your operative system from the list to get a list of all the available drivers and software for your printer compatible with your OS. You can also download the manuals from there.
For help on installing the drivers and software or troubleshooting any installation issues, click on the "Support & Service" tab and read or search the FAQS.
Sep 07, 2009 | Canon SELPHY CP720 Thermal Photo Printer
Having trouble with computer recognizing printer. Canon CP720
Check the printer default settings in control panel.
If you have them set to microsoft printer then change the default to the canon.
Jun 27, 2009 | Canon SELPHY CP720 Printer
Photo ink cartridge stuck
I had the same issue. Don't try to force the cartridge out though. After being stuck to the paper, tearing the remainder of the film won't get all of it out of the cartridge. You'll need to print a 'dummy' page to get the last bit to be pulled out and afterwards the printer will automatically release the cartridge allowing it to be pulled out normally.
Apr 21, 2008 | Canon SELPHY CP720 Printer
Canon Selphy 510
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple. vadim.y.astakhov@gmail.com
Feb 29, 2008 | Canon Selphy CP510 Thermal Photo Printer
Not printing from computer
i am also suffering from this problem...
Feb 15, 2008 | Canon SELPHY CP720 Thermal Photo Printer
Canon SELPHY  CP720 Printer Logo
51 people viewed this question
old marine
old marine
