Question about HP Computers & Internet
8762c HP pavillion will not boot
I got this machine to run old windows 98 games and it was running fine. Haven't fired it up in several months. Now it won't boot at all. Any suggestions?
  • HP Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Dec 12, 2012
  • knowlton hunter Dec 13, 2012
    My computer is not a laptop. It has been suggested that perhaps my computer is out of sync with the monitor since the monitor had been disconnected. I do get a screen stating that windows recognizes my monitor and that I should go to control panel to confirm - however since I do not have any screen to access that from this is currently not possible. Possible solution may be to drain capacitors and restart computer with monitor off for 30 seconds or so. I will try that first before taking ram or other system pieces for testing.
jigeo
  • 57 Answers
SOURCE: Memory Upgarde for HP Notebook
Everything I've read agrees with you on the upgrade to 2g.
HP Computer Memory Help should help with this and this help video from HP View Hewlett-Packard Laptop Memory Installation Video will tell you all the details.
Posted on Jun 01, 2008
scanner077
  • 52 Answers
SOURCE: Hp dv6753cl O/S Vista: my battery not charging
Hi there!
Perhaps you need to calibrate your battery. Please follow the instructions for the said procedure on this site:
http://h10032.www1.hp.com/ctg/Manual/c01078960.pdf
Have fun!
*Your vote is highly appreciated. Thanks in advance!
Posted on Dec 30, 2008
the_fire
  • 432 Answers
SOURCE: Faulty HP Laptop
Download the sata drivers for the laptop and slipstream the sata drivers with the xp installation disc ( making it bootable ) using nlite ( http://www.nliteos.com ) and then try and install - the other option is to disable AHCI in the bios or to make sure that it treats the hard drive in IDE mode and try and install xp.
If that does not help then post back and let me know.
The other option before you install xp is to go into recovery console and see if you can run chkdsk /r and see if that has any issues with the hard drive if it detects the hard drive.
If it does and you see any issues then if it cant fix them then there is something wrong with the hard drive possibly in which case download and burn the iso disc image from the hard drive manufacturers website ( diagnostic utility for the hard drive ) and run that and see if it reports any issues with the the hard drive. If that does not then it is obviously either a setting in the bios or because you have not got the SATA drivers intergrated with the xp disc.
Also if you can post back with a link to a photo of the Blue Screen of Death or post back exactly what it says.
Posted on May 07, 2009
Palmbeach
  • 185 Answers
SOURCE: touchpad won't scroll on hp pavilion zv5000 running windows xp
Hi Natasha
ZV5000
To get the scroll function working again, do the following and follow these directions exactly.
1. Click Start >Control Panel
2. Double click Mouse Icon
3. Click on Gestures tab
4. Place a Checkmark against Use Vertical Scrolling function and Use Vertical Scrolling function.
5. Click Apply > OK
6. Click the Setting button to adjust the scroll speed.
If you have tried the above and you couldn't see the "Gestures" tab, do the following.
Download the ALPS Touchpad Driver from the HP website >here< (if the link doesn't work, go to the HP website, find the ZV5000 and look for the ALPS Touchpad driver) and save it on your desktop.
Now uninstall the old drivers using Device Manager
1. Right Click on "My computer" and select Properties
2. Click on Hardware tab > Device Manager button.
3. Click on the + sign next to Mice and pointing devices.
4. Right Click on the Alps Pointing Device and select uninstall.
5. Double Click your new driver file that was saved on your desktop, to install it.
5. Restart the ZV5000. Windows will detect the hardware and will load the new drivers for it.
Check to see if the scroll function works. If not, do the following
5. Click Apply > OK
If you have followed exactly what I have said here, the scroll function will work fine. Let me know how you go!
Best wishes
Posted on May 26, 2009
mahjid
  • 202 Answers
SOURCE: 104-unsupported wireless network. HP pavillion
on your C:/ drive, your will see a folder names SWsetup, inside you will see the driver for WLan, reintall it. and also install the wireless assistant. good luck
Posted on Sep 08, 2009
Ato x600 hp pavillion won't boot
You could try disabling the on board video in BIOS.
Feb 04, 2013 | HP Pavilion Computers & Internet
ASUS M3A78-EM stopped seeing second drive
update your drivers and check the cables out as well
Jan 01, 2013 | ASUS M3A78-EM Motherboard
1972 olds 98 455ci starts and runs fine when its cold but once i've driven it for awhile it starts sputtering like its running out of gas
sounds like a vapor lock. older cars needed a set of points . they kept firing times in sync with fuel delivery , valves opening/closing try that.
Jul 29, 2012 | 1972 Oldsmobile 98
I can't run "Curse: The Eye Of Isis" in Windows Vista - any hope ???
I have a "virtual" copy of Windows running on my computer at home that use for running older games and applications. There are several free programs out there... Microsoft has one: Virtual PC and there is a Open Source version hosted by Oracle: www.virtualbox.org With a dual-core or higher, 2GB or greater RAM, you can run a virtual desktop with ease... All you'll need is a old copy of Windows to install (e.g. Windows XP, Windows 2000, Windows 98)
Nov 15, 2011 | DreamCatcher Interactive Curse: The Eye Of...
How do i reset my password on my hp elitebook 8730w
Here is a simple way to access Windows XP with Administrator rights and privileges if you have password protected your User account on your Windows XP system and can't remember the password(s) to login. Whenever Windows XP is installed on a system, it creates a default account called "Administrator" and by default this account is not password protected. Therefore, if you bought a brand name computer (such as Dell, HP, Compaq or Sony)or you have installed Windows XP yourself. You should be able to login to the computer through the unprotected.
You can log on as an administrator to assign a new password to your account. To do this, try Method 1.
Method 1: Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch on until you get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
Reboot your computer. As long as you don't press any keys (e.g. F8) during the boot-up the computer will startup normally.
If Method 1 is unsuccessful try Method 2.
Method 2: Reset Windows Password with SmartKey Windows Password Recovery.
Download SmartKey Windows Password Recovery from SmartKey Password Recovery Official site
Decompress the SmartKey Windows Password Recovery and note that there is an.ISO image file. Burn the image file onto a blank CD with the burner.
Insert the newly created CD into the locked computer and re-boot it from the CD drive.
Boot the PC with the CD Rom and Run the SmartKey, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, you have removed the password.
Nov 05, 2011 | HP EliteBook 6930p Notebook PC
Backyard soccer won't work on my 64 bit windows laptop.
Are you using Vista or Windows 7?
As far as i remember Backyard soccer is kind of an old game. It likely only works on Windows XP
May 04, 2011 | Computers & Internet
Trying to run my old HPP game in windows 7 but can't get compatability
There is a good chance that you won't be able to run that game on windows 7 with any sort of compatability mode. There is however another more advanced method that can be used to run very old games. You can set up a virtual machine on your windows 7 operating computer, and on this virtual machine install an earlier copy of windows, windows 98 for instance, which will run the game just fine.
To do this you need a copy of windows 98, thats the easy bit.
Then you need to download and install Windows Virtual PC and check your software compatibility. The download link can be found here.
Once you have Windows Virtual PC installed then you will need to set up your first virtual machine.
  • Start up the program
  • A wizard will pop up and help you through the creation of your first VM
  • Select "Create Virtual Machine" and then click Next
  • Select the Name For Your VM then click Next
  • Then from the drop down menu to the left select Windows 98 and click Next
  • Select "Using The Recommended Ram" then click Next
  • Select "A New Virtual Hard Disc" then click Next
  • My Suggestion is to leave these at Default, then click Next
  • Check over the details and click Finish.
That should see your first VM Setup. Now go to the Virtual PC Console, select the VM you just created and click start. You should see a window that pops up showing what appears to be a PC starting up. That is the virtual PC starting up just like your pc would. Starting up for the first time can take quite a while so be patient.
The VM should then display the message "Reboot and Select proper Boot Device or Insert Boot Media in selected Boot device".
It's at this point you need your copy of Windows 98, on you VM window you will see on the menu bar at the top of the window the drop down "CD" click on this and select your disc method, which CD drive the disc is in or if it's an ISO file select that option.
Once you have that selected then:
  • Press the space bar and the screen should change
  • Select boot from CD-ROM, press enter
  • Select Start Windows 98 Seyup from CD-Rom, press enter
  • Press Enter when promted to
  • Select Configure unallocated disc space, press enter
  • Select, "Yes, Enable large Hard Disc Support". press enter
  • Press Enter when promted, the VM will now restart
  • Repeat the first 3 steps
  • Setup should now be formatting your virtual hard drive
  • Press Enter when prompted
  • The Windows setup Wizard should now be running
  • Follow the wizard through and Windows will start installing
  • During this process the VM wil restart several times
  • Once the VM restarts and again promts to start from CD-Rom or Hard Drive, select Hard Drive, then press enter.
  • Once your VM starts up in Windows 98, proceed with the installation of the game and any other software it needs.
Once you've done all this you will have the perfect compatibilty platform set up for any old games you own, as it is Windows 98 not some mode stuck on the side of you version of windows.
This is quite a long and complicated method, but it will work and it will allow you to play just about any pre 2000 game going.
May 03, 2011 | Wanderlust Interactive Pink Panther Hokus...
I have a Windows 7 laptop, and I just bought Carnivores: Ice Age for some nostalgia. But now, after I have bought it and installed it, it will not run. I've gotten no error message describing the problem....
Hello VincentS,
Right ... Nostalgia (I had forgotten my solitaire games...
I used to let my hands do speed runs when trapped on
CONFERENCE CALLS)... I STILL HAVE my OLD system...
so running (old ) games (et al) is NOT AN ISSUE.
IF
you have an old Windows 98 system... run it there
Pentium, see below for requirements)
There are basic system requirements...
Carnivores Ice Age Specs
(I am an old "systems" guy so I try to stick to the
BASICS with PCs. (still running 98 and XP... ) only now skipping everything and jumping to Windows10
ELSE
To move it forward you must run windows 98
compatibility mode...
I had to look on the internet.. and found you a pretty good discussion (circa 2009). http://z3.invisionfree.com/The_Carnivores_Saga/ar/t766.htm
Interesting...
You just made me remember to check my coolant level before I fire up my OVERCLOCKED 98 system...
Thanks...!!
that could have been painful... (fried Celeron - Yum)
Hope it helps!
Carnac the Magnificent
Aug 18, 2017 | Wizard Works Carnivores: Ice Age for...
Password prob
what version of windows is it running?
Feb 28, 2008 | HP VECTRA VL PC Desktop
Computers & Internet Logo
103 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
