Question about Samsung UN46EH5300 46" LED 1080p HDTV With Built-In Wi-Fi
UN46EH5300 weak or no signal
Tried auto program several different times. Tried setting it up as I did out of box. Tried first connecting with standard cable cable and then component. Tried flippping between "air" and "cable" setting. Tried just about darn everything. Still snow.
  • 718 Answers
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Posted on Feb 23, 2009
SOURCE: component cables produce "no signal" or "check signal cable"
I had exactly he same problem and it fixed by pressing several times the "source button"
Posted on May 17, 2009
SOURCE: "Weak or No Signal" message on Samsung 26" LCD TV
I pressed mute on my television and about 5 minutes later it said weak or no signal.What do I do?
Posted on Nov 07, 2009
tvservice306
  • 458 Answers
SOURCE: Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Posted on Jan 01, 2010
Testimonial: "Thanks for the info! Very helpful!"
  • 3 Answers
SOURCE: can not get hd on LTN1785W tried component 1 &2 just blu scrn
do you subscribe to the HD, if you do you will have to activate it through the menu button, go into the aspect ratio and set it on 720p or 1080i press OK the it will run a test...press the "up" arrow and then press OK.
Now on Uverse you can only get HD through the HDMI or the Component,red green blue, outputs.
Posted on Jan 10, 2010
I have tried to auto tune my 43 inch samsung plasma keeps coming but with weak signal or no cable connection
Consider hooking the signal source with a box to the rear audio/video or component etc inputs and bypass the tuner in your set, use a box instead.
Dec 05, 2012 | Televison & Video
I do auto programing some chanels get program some don't
Hello
Check first your set top box's, or TVs antenna or ariel connection is tight or not. It it is Ok, if you are receiving signals from cable, ask the cable operator to check the signal strength at the cable end of your home. It is measure with a 'db' meter. If the strength of the received signal is very weak, the same channels should not mamorized, and strong signal channels only will lock in. If you are using external antena, try to reorient its postion.
Anyway your TV doesn't get sufficient signal strength.
Oct 19, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have the box installed and on. Now what do I do to get the local stations on my TV
What box - satellite/cable/digital-to-analog converter? This tv has a digital (ATSC) tuner built in. So if you are looking for OTA channels, use antennaweb.org or tvfool.com to find out what direction to point your antenna and what antenna you need. Then connect the antenna's coax cable to your TV. Antennaweb is very conservative and assumes an outdoor antenna. tvfool.com will list several more channels and the different antennas that are needed for various distances between your location and the station transmitters.
If you are sharing one antenna between several tvs or tv and other devices, you may need an amplifier in addition to the splitter. (Unfortunately, these can get damaged by surges as well. I've lost certain channels after a lightning strike turned the amp into a filter for one part of the RF signal spectrum.)
Once you have the antenna connected and pointing in the direction of the desired station, you will need to scan for channels. If this is the first time the tv is set up, you will be prompted for menu language, the input type and then asked if you want the TV to auto-scan for channels. Otherwise, hit Menu, use the left and right arrows to get to the Channels menu option and press the + button in the center of the arrow keys. Next use the up and down arrows to set the incoming signal (if needed) - the item is labeled Cable and is a Yes/No (again press + to select item and to enter the change). Continue down to the Auto-program and let that run. You can add/remove channels from the resulting listing with the Channel Skip/Add option just below Auto-program.
I hope this helps.
Jun 21, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
None of my inputs work
Are you using the same HDMI cable with each device? If so it might just be a bad cable. If this isn't the case it may be a system setting which needs to be changed or possibly something requiring tech support.
Aug 05, 2009 | Samsung Televison & Video
I am getting a (weak or no signal)
Hello glc_11489,
Have you tried to use an amplified antenna? I have found that this works very well.
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jun 12, 2009 | Philips Magnavox 20MT133S 20" TV
Signal interruptions on digital TV set
Weak signal is a weak signal, so not sure what if anything you can do. Buy a satellite subscription???
May 18, 2017 | Televison & Video
Displays weak or no signal
CHANNEL section
Feb 23, 2009 | Samsung Televison & Video
Screen shows no signal
HDTV sets are different from the old analog sets.
If your set is showing No Signal or Weak Signal you will have to do the following.
1) Connect an Antenna or Cable to the input on the back.
2) Go into the Channel signal source menu and select either the Air/Antenna or Cable option.
3) Go into the Auto Program Scan menu and SCAN in the channels.
Now you can watch available channels.
Dec 29, 2008 | Polaroid FLM-3732 Television
No signal error when turning on TV
check if have signal tuner frecuency intermediate or fi. and if tuner is bad maybe cost is 85 dlls
Jan 19, 2007 | Sony KV-32FS13 TV
Samsung UN46EH5300 46" LED 1080p HDTV With Built-In Wi-Fi Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
