I have luminous inverter in my home suddenly it started mcb tripping how to solve this problem
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: split ac runs for 2 hrs and MCB TRIPS
Hi and welcome to FixYa. I am Kelly
This is a sign of a compressor that has an armature dragging internally or the winding has a short to the chassis inside the compressor. Placing your hand on one with an internal short to the case will definately get your attention. USE a meter! (lesson learned the hard way too many times)
It really is not wise to keep trying to use the unit in this condition.
1. Higher electric bill
2. When compressor finally burns up and contaminates coolant system.... purging and cleaning the coolant system can be as costly as the compressor replacement.
3. There is a remote chance there is a chaffing wire from the outside unit to the inside unit. (Very remote)
A Service Tech will do a running check where he verifies the running amperage of the unit. High amperage = a bad / dragging compressor.
Kelly
Posted on Mar 02, 2010
What power inverter is required to back up retail general store?
Hello satyam, If you are looking for best inverter for your shop, then luminous inverter is best option for you. I think you need at least 5 kva UPS for your large area shop. Buy Best Luminous Inverter UPS for Home Online at Best Price
Oct 12, 2017 | General Televison & Video
Rangemaster Ceramic 110 randomly trips the MCB.
Electric rangemaster tripping electric - what size mcb? ' DIYnot ...
www.diynot.com > Forums > How to... > Electrics UK
Apr 6, 2013 - Cooker occasionally trips the 'Wylex B32 MCB' when almost everything is going. ... http://www.ebay.co.uk/itm/Rangemaster-Leisure-110-Electric-Cooker-/ ... Find the total load via the site below, a ceramic nit is 14kw shock:
Oven or cooker tripping electric, what to do next? - YouTube
? 3:11
https://www.youtube.com/watch?v=O42p_tWYgAU
Dec 21, 2011 - Uploaded by Richard Saupe
Hi Richard, i recently bought a all electric rangemaster cooker second ... I'm asking because our oven trips the breaker when we try to turn it on, ...
Frequently Asked Questions ' Rangemaster
www.rangemaster.co.uk/rangemaster-owners/faqs
For earlier specification110cm models, remove the storage drawer and the silver ...Ceramic and Induction models may be connected to a suitable 6mm cable ...
http://www.diydoctor.org.uk/forums/electrics-forum.html 2015-12 ...
www.diydoctor.org.uk/forums/electrics-forum-f182.xml
Jan 19, 2016 | Rangemaster Range Cookers Kitchener 110...
Heater works but trips after a minute
Hello
If u have 2 kinds of trip circuits
1) regular over current trip then there maybe a problem withthe mcb itself, so try another location that does not use that trip or higher amps trip .
2) if u have an mcb with special trip that also makes sure there is not leakage to the ground of toaster , then some toasters get the leakage after some time .
Feb 17, 2015 | Tefal Toaster Ovens
Why is induction motor saw blowing fuse shortly after starting?
If it is still trying to run as a DC system, it might be that the positive and negative are reversed.
May 03, 2014 | Saws
MCB keeps tripping
Could be a blocked outlet pipe were you carefull with the sealing washers.? if the pump is getting back pressure and struggleing it may overheat and blow or maybe remove the mesh filter if one is fitted
if a simple reason is a not apparent do not fiddle around any more isolate the supply and find an electriction there is serious voltage in the there enough to start a fire or kill you ! please be carefull best of luck !
Dec 09, 2013 | Heating & Cooling
As load is apply inverter trip
Tripping Of Your Inverter / Circuit breaker when you use Kitchen range Can be because of Overloading or because of Short circuit . If There is an Earth Leakage Problem , Your RCCB may trip if you installed one .
Get Checked by an Electrician . you may need to use a higher rated MCB and Wires .
Please Rate my answer and Support me
Nov 21, 2010 | Kitchen Ranges
Window 1.5 AC Problem During Day
Chack size of wire. Should be at least number 10 wire. Check loose connections. Call power company to check your voltage. This time of year in different parts of the country they have brownouts which is a voltage drop becaus of the load on the lines. Have power checked. Rus
Jun 15, 2009 | Heating & Cooling
DURING DAYTIME WHEN HOT OUTSIDE 35-40 DEGREES C, AC TRIPs off
units are not able to work properly above 90, 1.0 T not go for more than 1 room. is outside of unit clean? if not turn off power to unit then spray 409 or simple green or something along those lines of cleaners on the coil part (soak it real good) it should cover entire coil as much as possible. let cleaner sit on it for about 10 minutes then use water hose to rinse as good as you can. wait about 10 minutes then try unit - so work better.
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
