Question about Comtrend CT-507 Router
Access router What is the default IP for accessing the router? 192.168.x.x does not seem to work, so I am at a loss as to what to do. Also, is there any way I can set up port forwarding with it?
    President:
  • 2,961 Answers
There seems to be a lack of info on this model, but, if you go to control panel>network connections and then right click on your network card and click status and then click support tab. Here you will find your pc's ip address and the router address if your router is allocating ip addresses automatically, eg if your router address id not showing but your pc's ip address is 192.168.0.2, then your router may well be 192.168.0.1, or similair. the username will probably be admin and password either admin or 1234, unless you have changed it in which case a hard reset will be required by the way of a button at the rear or underside.
Posted on Jun 12, 2007
  • andrew pester
    andrew pester Jun 12, 2007
    sorry, you can use this web site to let you know if it can port forward for your router
    http://www.portforward.com/
First you should disconnect from the net... change the IP address of your Local Area Connection to 192.168.1.? (the question mark could be any number but 1) then open Internet Explorer, FireFox or whatever browser you use and type 192.168.1.1 in the address bar. You'll be prompted to enter username and password which are respectedly "root" and "12345". I've tried to portforward using the NAPT section. but... so far no result. let me know if you had any success
Posted on Jul 23, 2007
Factory default is 192.168.2.1 so try that.
Posted on Jun 24, 2007
5 Suggested Answers
SOURCE: Port Forwarding - can't access router management
did that already, using the ip given from running ip config. that is the problem.
Posted on Nov 10, 2007
marked
  • 6487 Answers
SOURCE: Remote Access
If you want to access your router remotely, you just need to enable remote management on your router so you can access it using your internet IP colon the port number usually its port 8080.
Posted on May 09, 2008
bunnydawg
  • 5158 Answers
SOURCE: Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Posted on Sep 08, 2008
SOURCE: port forwarding
hh nnnnnnnnnnnnnnnnnnnnnnnnnnnnnn
Posted on Nov 27, 2008
What are the 4-8 diget number in linksys wrt54g
The default IP address for the router is 192.168.1.1. If the router IP number was changed, then it will have to be reset to the default to access it. You can access the router from your computer using the URL: http://192.168.1.1 (the default IP number).
Apr 03, 2014 | Linksys Wireless-G WRT54G Router
I need to lock my router from neighbors using it
For that you need to secure it with WEP password you can set it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security then enter new password then save settings and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 27, 2011 | NetGear WNR1000 Router
My router seems to be destroyed. i tried to setup access point but right after that the light went red.. but i connect wirelessly. and my fone and my sisters' laptop can't connect to the internet...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 16, 2011 | Belkin Surf N300 Wireless N Router
What is the access number ? 192.168.1 doesn't seem to work
Those number look like three fourths of the IP address. It's not the access number. The access number is created by the person who installed your router or it can also be the default number found on the label of the router - consult your router's user manual for a definitive answer.
Dec 16, 2010 | Dynex DX-E402 Router
I have lost the installation cd to my linksys router and I need software to change the wep password. I cant seem to remember what I have set it to before.
You can know your password without disk too. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Oct 06, 2010 | Linksys Wireless-G WRT54G Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I forgot my RG54SE II username and passworn and i dont have the configuration cd anymore, can you help me please?
First connect your router to computer with ethernet cable.
Then you can access it with below link
http://192.168.1.1
or
http://192.168.0.1
if above not work then check your computer's ip address gateway ip is your router ip you can access router with gateway ip.
Type user as "admin" and password as "admin" or blank or "password"
If above not work then you need to RESET router to defaults.
For that press RESET button it is in back side of router.Press hold it for 10 seconds then all settings defaults then you can access it with above direction.
Dec 29, 2009 | MSI Wireless-G RG54G3 Router
Entered the wrong ip address
Different manufacturers have differing setup so without the details of the make and model of the router in question it a little hard to help.
Most routers will have the ability for you to reset it to factory default by a button or such on the unit itself - refer to the install documentation that you got with the modem - if you dont have it you may need to aska friend to borrow their PC and access the manufactures support pages for help.
Jul 13, 2009 | Computers & Internet
Cannot connect to 192.168.1.1
You must check if your PC is getting correct IP from your router by running ipconfig on DOS command. The Default Gateway must shows 192.168.1.1. Just to be sure this IP is accessible, run a ping test (Ping 198.168.1.1).
C:\Users\PC>ping 10.1.1.1
Pinging 10.1.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Ping statistics for 10.1.1.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\PC>
You will see the above results if the test is successful. If it failed, possible a Firewall is blocking the PC to access the Router. Try to disable it and see if it will works. If the same issue or even the test passed but can't access the IP address, reset the router to factory defaults by pressing the small hole at the back of the router. Then do the above steps again to see if you can now access it. Hope this helps.
Jun 14, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
Cant get the wireless connection through the AP router
first check ur computer IP address (if not getting from DHCP then try static IP address) & default gateway.
Mar 20, 2009 | CTG 54Mbps WIRELESS ACCESS...
Comtrend CT-507 Router Logo
521 people viewed this question
Top Comtrend Computers & Internet Experts
Marvin
Marvin
Prashant M
Prashant M
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
