Question about Samsung CLP 300 Laser Printer
Replace pickup roller on samsung clp315
Is there a step by step tutorial as to how to replace the pickup rollers on the samsung clp 315
namizhka
  • 148 Answers
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Posted on Sep 16, 2008
  • 220 Answers
SOURCE: I have the replacement pickup roller large rubber
two screws when you ope front door,at the back 4 screws.the front where screws are they are 2 lugs holding cover wedge out and pull cover off.
Posted on Jun 22, 2009
nakshatraipu
  • 241 Answers
SOURCE: Samsung CLP-315 eats toner. Cartridges last almost
YES WE HAVE PERMANENT SOLUTION FOR CLP 315
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Posted on Nov 18, 2009
Lin0
  • 6 Answers
SOURCE: how to refill toner cartridge for Samsung CLP-315
Yeah actually theres "something" about this particular toner cartridges...check this out: http://sites.google.com/site/refillinstruction/Home/clp-310-refill
Posted on Dec 19, 2009
picipolman
  • 9 Answers
SOURCE: Replace imaging unit error i
Finaly got it.
Pull out the four toner cartridges and also the drum unit , staying in front of the printer , on the right side of the drum unit, you will find a small box with two contacts.
You need to solder a 63ma ( worked for me) fuse in paralel with two rezistors that it contains. It is hold by a small klipp - it is easy to get it out. You also need to empty the waste toner behind the opc , drum or watever you call it . Restart the printer after putting alltogether.
The second solution is to buy a new one but its price talk for itself - close to a new printer :-)
Good luck.
Posted on Jan 27, 2011
My Samsung CLP-315 Laser Printer will print about a half page and then jam...everytime!
does the jam came out to the exit and stuck there or it jam in the printer or before the pickup?
if it got jam at the exit. the exit sensor is faulty it got to replace.
if it got jam in the printer. the transfer belt or fuser is faulty. both got to replace
if it got jam before pickup. pickup roller got to replace.
May 09, 2010 | Samsung CLP 315 Laser Printer
Download software to run printer model clp315
Hi
Thank you for your query
Please see the following link for your requested driver
http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06010200&prd_mdl_cd=CLP-315%2fXEU&prd_mdl_name=CLP-315
I hope this has been useful
Mar 15, 2010 | Samsung CLP 300 Laser Printer
Samsung 315 Color laser printer acts like it's going to print, but doesn't feed paper. No paper jam...
Sounds like you have a roller turned glossy.
Open your paper feeder drawer and locate the pickup roller. It's rubber, or like rubber and will either be glossy or a little dirty. Now take a light bristle toothbrush and clean the roller with alcohol, remembering to roll it as you clean. Allow to set dry for 20 minutes and try again.
Mar 07, 2010 | Samsung CLP 315 Laser Printer
CLT-k409s cartridges not compatible with my CLP 315 printer
return the cartridge to your vendor, and have it replace with the right cartridges for your printer
Jan 22, 2010 | Samsung CLP 315 Laser Printer
Exit Sensor Problem on Samsung CLP-315 Colour Laser Printer
The same thing has happened to me, my CLP-315 stopped printing (paper only comes out halfway.) Samsung told me that there's no service center in my area and I would have to ship the printer, plus it would not be under warranty... making it cheaper to buy a new one! So after a quick search, I found this page.
I ordered the 0604-001393 Part from SamsungParts.com, ($11.75 total cost) and will post video/photos on youtube of the repair process.
Jan 20, 2010 | Samsung CLP 315 Laser Printer
How to check wich toner is out of ink (Samsung CLP315)?
Press and hold the stop button for 5 seconds...a configuration report will be printed out. Reference page 41 in this link to Samsung for your CLP315.
http://downloadcenter.samsung.com/content/UM/200911/20091106143806375/Guide_EN.pdf
Dec 27, 2009 | Samsung CLP 315 Laser Printer
Printer not operating correctly
usually dirty rollers cause this problem. if you can open your printer and get to the rollers then you should be able to wipe them with baby wipe or something of this consistancy, if this does nothing then you should have a cleaning service on your printer software whcih may also help.
Jun 29, 2009 | Samsung CLP 315 Laser Printer
How to refill toner cartridge for Samsung CLP-315
Jun 10, 2009 | Samsung CLP 315 Laser Printer
Refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Feb 21, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP 300 Laser Printer Logo
119 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
