Question about Home Security
I have a Brinks Model #5074 anti-theft safe. I put the correct combination on the keypad. The light goes on, but I can't open it. What shoudl I do?
This safe has a keypad. There is a latch that pulls up to open the safe. I pulled on the latch, but the safe wouldn't open.
    Top Expert:
  • Home Security Master
  • 79,847 Answers
Call a locksmith.
Posted on Oct 06, 2016
SOURCE: how to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Posted on Jan 06, 2010
loxmith
  • 21 Answers
SOURCE: I lost the combination for my brinks home security
Hi, You can contact Honeywell at 1-800-223-8566 . They are providing support for Brinks safes.
Posted on Aug 02, 2009
loxmith
  • 21 Answers
SOURCE: Same problem - I have the key but no combination.
You can contact Honeywell, they are providing support for Binks safes. Their number is 1-800-223-8566
Posted on Sep 08, 2009
SOURCE: I have the Brinks safe model 5054. We recently
my safe is lock and i dont have the combination but the key is
still in the lock. so what can i do to get in to the safe.
Posted on Nov 03, 2009
SOURCE: sentry safe model 1330.
A Locksmith would say If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Posted on Aug 09, 2010
I have a Brinks Home Security Fire Resistant Safe Model 1060,5055,5060 (Sisco) and I lost the key to open it.Where can I get a replacement key. I have the combination but also need key to open it.
Only from the maker First Alert or a Brinks registered locksmith. They make you jump through a lot of hoops, often including a sworn and notarized letter saying the safe belongs to you.
www.justanswer.com/home-improvement/expert-dr-fix-it
Hi First Alert now handles the fire safe products from Brinks and you may go to the link below to fill the request letter, then have signed at a notary and fax to First Alert for the replacement key to be sent -
http://www.firstalert.com/faqs/safes/how-can-i-replace-the-keys-or-get-a-new-combination-to-my-safe
How to Open a Brinks Fire Safe ' Hunker
https://www.hunker.com > Home Hacks & Answers > Home Safety > Home Safes
May 16, 2009 - A Brinks fire safe uses a dual-lock system consisting of a key and a numeric combination. To open the safe, you have to unlock the combination a specific way, then use the key.
Breaking Into A Brinks Safe - YouTube
? 1:07
https://www.youtube.com/watch?v=GB6Oy5O5yuA Jun 13, 2013 - Uploaded by Inspiring Dreams Daily
Kyle breaking into a Brinks Safe. Imagine the possibilities hahaha Check out the the other videos to see how ...
Brinks Safe Picked ( Lockpicking) - YouTube
? 0:58
https://www.youtube.com/watch?v=DlRfLy6f7sI May 27, 2009 - Uploaded by Anderson Video Production
Up next. How to open safe with lost combination, key, re-purpose repair reuse, part 1 of 3 safe cracking ...
How to Get Brinks Fire Safe Key Sapling com
Jan 29, 2018 | The Home Security
I have a brinks safe that has a combination lock and a key but i cant remember my combination and was wondering how I can reset it. Model number 5059
Each Brinks 5059 safe has a different default combination, so to get the original combination you must either contact Honeywell (the parent company for Brinks safes) at 1-800-223-8566.
You need to send them a notarized letter showing safe ownership in order to get the master combination. When you call Honeywell, you will need to provide your safe's model number, the serial number (found on the right of the safe, near the model number), and your key number.
Jan 04, 2017 | Home Security
Is there a default combination for brinks model 5054 safe
Contact brinks they may have a master code to unlock your safe...or try a good lock smith,they may have access to the code.
Jun 11, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
Cant open my brinks safe model #5050
I need a replacement key for Brinks model 5050 key # 21
Sep 25, 2012 | Sentry Fireproof Safe
How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
Sep 01, 2010 | Sentry Fireproof Safe
I have a Brinks home safe model 5074. The combination no longer works, and the batteries are still good. The combination worked just last week. I do not have the keys. Any ideas?
I have a Brinks model 5074. I did the notarized statement to Action and they sent me a set of keys to open the safe. However, I also asked for the instructions on the sequence to set the electronic key pad. Obviously, they didn't send the ops instructions and it's a holiday weekend. Can you provide the insturctions?
Nov 17, 2009 | Check Point Network Adapter
Brinks safe model # 5054
go to honeywellsafes.com apparently brinks was bought out
Jul 28, 2008 | Computers & Internet
Home Security Logo
4,027 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
