Question about Canon PIXMA MX432 Wireless Office All-in-One
How do I fix the alignment on my Canon Pixma MX432?
When I print something everything is crooked, the words or pictures are coming out asymmetrical. I already tried the automatic and head alignment on my printer. This happened after a paper jam. I thought it was because my ink was low but after I changed the ink the words and pictures were still not lining up with each other.
  • 11 Answers
SOURCE: Paper Jam Error
Just clean and observe yaar , I dont have more knowledge , In my knowledge i am telling , just clean your printer and see yaar ,
Posted on Aug 28, 2007
marsrover
  • 682 Answers
SOURCE: Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Posted on Mar 20, 2008
SOURCE: Won't take paper
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click to return to step 2 above.
Posted on Apr 03, 2008
worldvet
  • 859 Answers
SOURCE: Canon iP90 pixma printer: Black ink
Sorry you are having trouble getting help. You can exit this thread anytime and you'll be prompted and or receive email to nominate the expert with the best solution. At this point you can invoke the unresolved money back guarantee.
In your case, this comes up a lot and Canon does not offer out print heads, its a factory fix, which is weird as most of us can get them for the other printer makers.
One problem does come up is if you have been refilling your black or buying refilled ink cartridges then this does happen all the time because the pigment is not small enough to Canon standards than the nanometer holes in the printhead.
Assuming you've been using the Canon ink and this has happened. You have used the machine beyond is know MTBF or Mean Time Between Failure rate. This would explain everything and your solution is to get another machine, preferably one where you can replace the print heads in the future. So that leaves out Canon.
In summary, exit this thread, when prompted choose unsatisfied or whatever it is they putting in front of you now, or wait for the email and then do it. You can also contact Fixya.com customer support and do a full write up, but copy and paste the url of this thread first so FixYa can take note of who was failing you. Sorry I didn't get hold of you earlier and give you a straight answer.
Regards,
Worldvet
Posted on Aug 01, 2008
iservice
  • 318 Answers
SOURCE: paper jam sending faxes
It is the document stop arm that is broken.You can remove it.The machine will work without it.
Just make sure you remove the document stop arm and not one of the other sensor flags in the document feeder.
Posted on Oct 29, 2008
Dont printer work,mx 432
Canon U.S.A. : Consumer & Home Office : PIXMA MX432
www.usa.canon.com > ... > Office All-in-One Inkjet Printers
Canon Inc.This begins with built-in Wi-FiĀ® 1 for printing and scanning virtually ... you to easily multi-task while your PIXMA MX432 is at work for all-new levels of efficiency. ... Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1.
Oct 20, 2015 | Canon PIXMA Office Equipment & Supplies
How do I fix an error 6000 on my MX432 printer
In the maintenance program that comes with the printer there should be an option to align the nozzles. You should run it a few times to assure the problem is corrected.
Aug 27, 2014 | Canon Pixma MX432 Wireless All-In-One...
My canon mx432 printer prints blurry? I tried everything ?
have you tried the head alignment tool? which comes bundled with the software?
Mar 18, 2013 | Office Equipment & Supplies
I DO NOT HAVE A MANUAL FOR PRINTER PIXMA MX432
You can find Brochures & Manuals for the Canon Pixma MX432 by visiting the product specific page on their web site.
Here is a link
- Michael
Oct 01, 2012 | Canon PIXMA MX432 Wireless All-in-One...
Canon pixma mx432 printer error 5100
I have a Canon mx432 that was new, but gave me a 5100 message that I couldn't clear. I cleaned the transparent belt that guides the print cartridges, and now it works great. I spent hours on it until I cleaned that strip - - nothing else worked
Sep 12, 2012 | Canon Pixma MX420 All-In-One Printer
Code 5100 error canon MX432
Chris Bell, thanks for your solution. My Canon MX432 has been blurry for a week. No amount of print head aligning / cleaning / rebooting was going to fix it. I cleaned the "timing strip" as you've indicated and voila! Problem solved.
Aug 22, 2012 | Canon PIXMA MP540 All-In-One InkJet...
Alignment
The way that I fix it is to download and save the internet page(copy and past only the pic or words) into WORD , then print the file.
Feb 18, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon MX310 not printing properly
If you are running Windows XP, you should be able to go to Control Panel> Printers and see your printer. Right-click and go to properties. From there you should be able to align the print cartridges and that should fix the problem. If problem persists, contact your manufacturer.
Jan 12, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX432 Wireless Office All-in-One Logo
1,735 people viewed this question
old marine
old marine
