Question about Black & Decker CTO650 1500 Watts Toaster Oven with Convection Cooking
No Oven but still Toasts
My Toaster Oven still toasts but the oven function no longer works. It does not heat up nor does the blue indicator lamp light. I've checked all knobs to make sure they are set to "oven". I was able to get inside the right-hand side, but no obvious non-functioning items (i.e. loose wires, broken wires, etc). I called customer service but they only recommended a new oven or a repair center. I have not tried yet but I can follow the wires logically and with a continuity tester to try to determine the faulty item. Any help would be appreciated (e.g. machine idiosyncracies, where to get parts, etc.) Thanks, merl
  • 5 more comments
  • Ray Wojtak Jun 12, 2007
    Tried cleaning the contacts last night, no success.
    I then followed the wires to determine logically (without a schematic) how the current flows. If my continutity tester is correct, the switch that sets the oven temperature & selects "toast" no longer functions. This knob also physically sets the pressure on a set of contacts. Can this be repaired/replaced? Where can I get parts?
    Thanks,
    merl
  • Ray Wojtak Jun 18, 2007
    I dis-assembled & removed the switch in question. The housing just snaps together so I carefully pried apart one end of the housing & noticed one contact was stuck in the open position, its arm was rubbing against the housing. A small file & a little elbow grease later the contact & arm were free floating. Snapped that end back on then checked the other end (since the switch was out) but looked fine. Re-assembled & the oven now heats!
    Thanks for all your help & suggestions!
  • Anonymous Dec 23, 2007
    I have the same problem with a CTO650 that is less than 1 year old. I use to be an appliance repairman and have determined that the toast/bake control is bad. Black & Decker tells me that that part is not available. I can not find my reciept so warranty is not an option.
    Ivan
  • Ivan 55 Dec 23, 2007
    I have the same problem with a CTO 650 that is less than 1 year old. I use to be an appliance repairman and have determined that the toast/bake control is defective. Black & Decker tells me that the control is not available. Warranty is not an option because I do not have my sales reciept.
  • Anonymous Mar 28, 2008
    I did the same repair as merlin (thanks)... used a dremel to shave the housing that was rubbing the actuater bar.. did a little bend in bar and put back together.. works again... dlshea84
  • bbchic43 Jul 23, 2008
    can anyone explain how to fix this in simple terms so that someone who has no idea about taking apart and fixing a toaster oven can fix it. i opened up the right hand pannel and read the other solutions but am still confused. when i turn the button from toast to oven the switch still turns so that is not stuck, but i am not sure what else to check for...
    thank you so much
  • Anonymous Dec 21, 2008
    how do i take the right side off so i can get inside the TR0651?
Never buy black & decker they don't supply parts they want you to rebuy the same junk over & over. its a shame this is what american companies have become buy japanese they last longer and make replacement parts.(I'm not unpatriotic just an informed consumer).
Posted on Aug 21, 2008
I did the same repair as merlin. Unplug from wall.. take the side panel off. Take knob off the temp. control. Loosen 4 wires that go into the module. (make a note of which wires go where)... take 2 screws out from the front of unit. The module can now be removed. use a small flat balde to open the bottom end.. slowly. .. a small ball bearing may come out (it's needed). Then you will see the contact arms that depress in to a small spring.. if contact is not being made. you need to file the housing that is rubbing on the one contact bar.. I also had to take it out and bend it a little to make it contact correctly.. once you have both arms depressing normally.. you can put back and test.. work good for me.. thanks merlin
Posted on Mar 28, 2008
Hello, I had the same problem on the CTO 650C. Toasting but no oven. It turned out that the housing of the temperature selection dial had melted slightly during use. There was a small obstruction inside the plastic housing preventing one of the spring loaded contacts from making a strong connection (possibly some plastic from the melting covered the contact). I simply removed the build-up and it is working so far.
Posted on Sep 29, 2008
This suggestion worked for us.
Posted on Jul 17, 2007
Hi. I have a B&D toaster with a timer which works slightly different than yours, but probably close enough for this possible solution. My oven stopped working recently, but the toaster function worked normally much like your problem. What I did to get the oven working again was to first unplug the toaster power cable from the wall outlet, then remove the right side cover as you mentioned, get a small piece of sandpaper with fine grit and carefully sand between the electrical contacts that open and close when a knob or button is pushed. You'll have to try turning a knob and/or pushing a button while looking for contacts that come together and spread apart. On the other hand, these same contacts may be greasy as well. Take a Q-tip , trim it down with some scissors so that it can fit between the cantacts without bending them, dip it in alcohol and clean between the contacts. Again be very careful not to bend the contacts out of place. These contacts are in a tight space, so be patient and set aside an hour or so to perform this. This might get the oven function working again and save you the price of a new toaster. Good luck, tuneman
Posted on Jun 11, 2007
My Toaster oven top elements are not heating up on the toaster function
If the bake function still works you can keep it for that. But the heating/toasting elements are not meant to be replaced / repaired because the lawyers told them there is too much risk.
Another matter if still under warranty.
Dec 14, 2017 | Toaster Ovens
My calphalon toaster oven will not toast top of bread? Why?
The upper heating element may have failed or the toasting function may not have been selected.
Oct 06, 2014 | Calphalon Convection Oven, Extra Large
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
I have a Black & Decker Toaster Oven Plus. The only number I could see was, toaster listed 228E. It bakes, and toasts only the underside of bread. It no longer broils. Do I need to replace the top element,...
Mine has The same problem and I am trying to fix it I don't see anything burnt and everything seems to be put together and write and I can't understand why the top bars would not heat up,I need help to prepare this thing I love it so much
Aug 13, 2013 | Black & Decker Toaster Ovens
This toaster no longer toasts food evenly, it takes twice as long, it appears that the broiling coil element may not be heating...Can these elements be replaced?
the elements can be replace, BUT, it is just not cost effective. you can buy a new toaster for less the the cost of repair.
Jan 03, 2011 | Cuisinart Toaster Ovens
The blue light does not go on and the heating element does not wo
The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
Cuisnart Toaster Oven Broiler TOB-165 Element
there not replaceable . metal straps are welded to the ends to make the electral connections . thats why there are no elements for this oven , sorry factory-store-home-dump AS FAST AS WE CAN
Jan 20, 2009 | Cuisinart TOB-165 1500 Watts Toaster Oven...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & Decker CTO650 1500 Watts Toaster Oven with Convection Cooking Logo
1,128 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
