Question about Samsung DynaFlat TX-P3064W 30" TV
Color Temp Change
When my TX-P3064W warm up the set starts to change color tempature. It has started now that it is warmer in the house due to weather (above 70). It does it with HD RGB feed and S-video. The TV is around 2 years old and cost aroung $800. It was made in December of 2004. Will it be worth fixing? Any ideas? Thanks
    President:
  • 3,130 Answers
You have a picture tube problem, or bad capacitors in the screen circuit. I'm afraid not a job for the end user. A repair shop should be able to assist you in this repair. good Luck
Posted on Jun 11, 2007
  • Larry  Dillon
    Larry Dillon Jun 11, 2007
    I am sorry there is no other solution for you my friend, i do not have a magic wand to fix your TV set. Now if you have a crt rejuvenating device, maybe you can check the picture tube, or If you get an ESR type capacitor checker, you can see if the boost voltage cap is good, other then that, you will need to get this set repaired at the repair shop, but they will most likely tell you it is not worth it.
Bought cropped sleeve coat. not practical in very cold weather. brushed camel color wantarm warmers what color is suggested do you sell arm warmers
Well, your post was a little hard to read. Is the coat a camel color? And what were you asking involving arm warmers? I can suggest some options for the coat as far as being able to wear it in warmer weather. Do you have a photo?
Oct 18, 2015 | Clothing
Just how do i make my homes look warmer, stylish and colourful?
NEUTRAL COLOR ON WALLS, PICK ONE BIG WALL AS AN ACCENT WALL, PICK A WARM COLOR, LIKE AUTUM RED.ORAQNGE..GET A CARPET THAT HAS A WEE BIT OF THE ACCENT WALLS COLOR IN IT AND SOME PILLOWS TOO, SOME ART WORK OR A CLOCK., YOU NEED THAT COLOR YOU FEEL COZY IN ON TEH WALLS, FLOOR AND EYE LEVEL, AND YOU'LL FEEL MORE AT HOME AND WARMER.. RED IS A GOOD WORM COLOR.. AND A LIGHT BROWN/GREENN BRWN WOULD BE A GREAT MIX..
Aug 23, 2013 | Computers & Internet
Gray picture for all RGB inputs
Check the connections. If connections to RGB has conected wrong, this type of fault will occur. Follow the color codes of wire ends both at tV and DVD.
May 27, 2012 | Samsung DynaFlat TX-P3064W 30" TV
We have Chrstie 2 LX100s, recently one has a warmer color
reset the settings to factory default. if that doesn't change anything, clean the dust out of the projector and check the second diffuser lens (fly-eye) next to the lens. also check the polarizers next to the lcd panels. they tend to fry due to excessive dust and heat.
Oct 23, 2009 | Christie RoadRunner LX100 Multimedia...
I just bought Sony Bravia flat screen television set today. The images on the screen are 90% greenish in color. How do I set it right to the right human color ? Please help ASAP or I will return the TV set...
go into menu, look for picture or setup mode. in setup look for chroma/color & tint/tone controls. you should be able to adjust to personal preferences. one other setting, is the color temp setting. this will allow you to change to warmer back wash. hope this helps because the Bravia is a good set
Sep 14, 2009 | Sony BRAVIA KDL52XBR2 Television
I can not change the thermostat setting on the unit. Whenever I try to change it, it reverts back to the previous setting.
The thermostat will display the current tempature in the room. When you press the buttons to change the tempature and you see it change back it is probably going back to the room tempature display but still keeping the temp you set it at. Also make sure the "hold" feature is set or the temp you choose can change at different times during the day due to the programmable features built into the thermostat.
Sep 08, 2009 | Honeywell Heating & Cooling
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Color Problem
set the temp at medium but the best is to set it at the factory setting it will last longer that way you can over heat it you are adjusting tempature to adjust color.
Nov 23, 2007 | Polaroid FLM-3225 32 in. LCD Television
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Samsung DynaFlat TX-P3064W 30" TV Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
