Foxconn ls36 beep sound error
On powering continuous beep sound coming
3 Suggested Answers
  • 37 Answers
SOURCE: phoenix bios two long beeps one short then
According to:
http://www.pchell.com/hardware/beepcodes.shtml
sounds like a memory problem. Take out all your memory cards and replace them one at a time (in different slots) until you find a configuration that works. then add in the other cards until you get the error message again.
Posted on Jan 04, 2010
  • 3799 Answers
SOURCE: manual for foxconn ls36 motherboard
Go to Foxconn website.
Posted on Mar 17, 2012
Long continuous loud beeping sound coming from the foxconn a7vmx-s motherboard. Please help
These are called Beep Codes. The kind of beep indicates that the motherboard cannot post, and gives you some idea of what is wrong. These codes should be located in the booklet that came with your motherboard or the computer. You can also try the computer manufacturers website, hopefully they posted a manual for your computer.
Sep 19, 2013 | Foxconn A7VMX-S Am2 Ddr2 Motherboard
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
1.Suggest me the type of ram which is supported Foxconn 8657MF-series. 2.When i installs DDR400 RAM of 256MB it gives continuous beep(bee-bee-bee) sound. 3.What are the beep codes of Foxconn...
the beep sound on system starting before booting starts refers no RAM in system, if you need to upgrade your RAM then go for DDR-SDRAM PC3200 200MHz 512MB 0r 1GB.
Jan 24, 2011 | Foxconn (865G7MC-ES) Motherboard
I'm hoping maybe you can help me! I have a Foxconn A79A-3 mobo and I'm getting the "beeps" I get nothing from my computer screens when powering on. It does 2 fast with not much time inbetween them,...
No beeps Short, no power, bad CPU or motherboard, or the CPU is not installed properly. One long beep, then two short beeps Video problem Continuous hi-lo beeps CPU overheating Repeated long beeps Memory error All other beeps Memory related error
Aug 26, 2010 | Computers & Internet
I get continious beeping in my computer with no display
If you are getting hi lo beeps, refit CPU and heatsink
If continuous long beeps, check memory is seated correctly, if more than 1 stick, try each one on its own, 1 may be faulty, or incompatable
Aug 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Phoenix bios two long beeps one short then continuous long beeps, no video. Foxconn mobo C1 LED post error.
According to:
Jan 04, 2010 | Computers & Internet
Beepcode: single beep every 2 to 3 seconds continuous
Try taking out the ram and reinserting it also anything that is in the PCI Card slots.. other solutios is take and unplug each device and see if the boot up changes it will sometimes give a read code it might help eliminate the problem
Jul 26, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
Foxconn LS36 mobo , front panel (34pin) connection DETAILS needed
Dell has never published the pin-outs of their proprietary ribbon connectors to the front panel
Jun 03, 2009 | Dell OptiPlex GX270 PC Desktop
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Computers & Internet Logo
David Payne
David Payne
