Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
We have a Canon imageRUNNER2200 and do not have a user guide - we need instructions on how to set up speed dial for faxes please.
  • 168 Answers
Additional functions key then on right colomn look for adress settings follow steps
Posted on Jan 14, 2009
How to specify fax machine to dial '9' before fax number?
Hello ilay,
This procedure is from the Brother FAX-4100e FAQ link:
Storing Speed Dial numbers:
You can store Speed Dial locations on your machine(*). Once you have programmed the Speed Dial number on your machine, you can dial the number by pressing Search/Speed Dial, #(Pound Sign), the Speed Dial number, and then Fax Start.
*The number of locations you can store varies by machines. Please refer to the User's Guide for your machine. The latest User's Guide is available in the Manuals section.
To store Speed Dial numbers follow the steps listed below:
1. Press Menu.
2. Press the left or right arrow key to select Fax and press Set.
3. Press the left or right arrow key to select Set Auto Dial or Set Quick Dial, and press Set.
4. Press the left or right arrow key to select Speed-Dial and press Set.
5. Use the dial pad to enter the location (Speed Dial number) where you wish to store the number and press Set.
6. Enter the number you want to store (up to 20 digits) and press Set.
Note:
If you want to enter a pause in the dialing sequence (to wait for an outside line, for example), press Redial/Pause as you're entering digits. Pressing Redial/Pause enters a 3.5-second pause when the number is dialed, and a dash appears on the screen. If you need a pause longer than 3.5 seconds you can press Redial/Pause as many times as needed.
7. Use the dial pad to enter the name or company name (up to 15 characters) and press Set.
If you want to store the number without a name, just press Set.
8. Return to STEP 5 to store another Speed Dial number or press Stop/Exit to exit the menu.
[Here's the web address for the Brother FAX-4100e FAQ]
http://welcome.solutions.brother.com/BSC/Public/Templates/FaqEndPage.aspx?NRMODE=Published&NRNODEGUID={30FA9470-D303-4B5B-8BDC-89B1CBA491AE}&NRORIGINALURL=%2fBSC%2fpublic%2fus%2fus%2fen%2ffaq%2ffaq%2f000000%2f002000%2f000004%2ffaq002004_010.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dfax4100_us&NRCACHEHINT=NoModifyGuest&prod=fax4100_us%C2%AE=us&c=us&lang=en#one_7
[Here's a link to the FAX-4100e users guide]
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 10, 2010 | Brother IntelliFax-4100e Fax
Am I able to fax to multiple recipients with canon lc 2050p?
Yes. Here is a link to your Canon Laser Class 2050P fax machine's User Guide. Reference pages 5-1 through 5-28 for Speed Dialing, One-Tuoch Dialing, and Group Dialing. Speed Dialing must be set up before Group Dialing can be assigned. Group Dialing will accomplish the multiple recipients sending.
http://www.actcopiers.com/Manuals/Canon_Laser_Class_2050P_User_Manual.pdf
Dec 14, 2009 | Canon LaserClass 2050 Plain Paper Fax
Group speed dial option is not lit up and will not let me click on it.....
http://www.brother-usa.com/Manuals/Default.aspx?WT.cg_n=Support&WT.cg_s=Manuals
Pages 5-1 thru 5-3 in the Users Guide cover One Touch, Speed Dial and Group Dialing (Broadcast Dialing). Apparently one touch and/or speed dialing need to be set up first. Hope this helps.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
Canon Pimma 850 wont faX
Here's a link to the online user's guide for your machine, which includes fax instructions.
Check to be sure you have connected the phone line correctly, set up the fax settings with the correct mode, etc. and the recipient's number is dialed correctly. Try to send a manual fax to begin with, and be aware that you have to use the auto doc feeder to do this.
If you're still having problems after working through this, reply with more details about how you're trying to send the fax, ie from computer or manual, etc and we'll help you to sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I do group faxing from my Canon L80 fax ?
Click here and download the user guide. The process is on page 6-13. You will most likely have to set up the numbers of the group in a "One touch speed dial" or "coded speed dial" before you add them to the group. Remember to leave the "one touch key" that you want to use for the group dial blank. Hope this helps....
let me know if you need anymore help.
Nov 13, 2008 | Canon FAXPHONE L80 Laser
How do I set up the speed dial function on the Canon L120. I have no manual
You can download manuals here. Instructions for setting up Speed Dialing are in the Basic Guide.
Jul 24, 2008 | Canon Office Equipment & Supplies
Canon Fax Machine Super G3 High-Speed Facsimile
The header needs to be changed in the User soft switches under "User Settings" - Unit name and Date and Time. Settings differ slightly depending on the model. Please stipulate the model name for explicit instructions.
Jan 07, 2008 | Office Equipment & Supplies
Speed dials
I'm not sure if this will help because I haven't seen a 2060 control panel but most Canon fax machines use the same process. Press either "menu" or "data registration" button. (Again -I'm not sure of 2060 control panel.) Display should read "user settings" Press the "down arrow" (looks like an upside down triangle) until the display reads "tel settings" Press "set" Display reads Speed Dials Press "set" Display should give the # of the speed dial (ie. Speed Dial 01) Press "set" Display reads "tel number" Press "set" input # you want to send faxes to Press "set" Display reads "Name" Press "set" use letters on keypad to input receivers name (ie. For letter "C" press #2 three times, you may have to use the arrow keys to move the cursor for names such as BC Corp) Once name is input - you guessed it- Press "set" you will now be presented with various other send options which most people/businesses never use. You can hit stop to return to normal mode. After inputting speed dial #'s & names,you can print a list of what you have input by getting back to the "Tel registration" screen & pressing the report button. I can be reached @ bspier@carlsonsupplies.com if you need more assistance. Good Luck!!
Jun 09, 2007 | Canon LaserClass 2060 Fax
Computers & Internet Logo
321 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
