Question about Whirlpool LSQ8000 Top Load Washer
Whirlpool Inglis IP44002 Top Loading Washer
This washing machine is only 2 years old. I am able to start the load but when it's done filling with water it doesnt spin or do anything despite adjusting the knob. The electrical outlet is working.
  • Peter-G Burke
    Peter-G Burke Dec 19, 2007
    Same as above...power is there, but once it fills, it stops...outlet is good, power is OCASIONALLY getting there, but no movement once the waer fills...
What I tried was pushing the lid down and I could hear the machine trying to kick into a spin so then while pressing the lid down i rotated to cycle knob slightly ahead and the spinning started. So I geuss I need to fix the connection between the lid and the machine?!
Posted on Dec 21, 2007
It could also be the "driver/coupler" between the motor and the transmission...in which case, you'll have to take the outside of the unit (top, and three front sides) off (don;t worry they all come off together) and unscrew the "Diverter" and the motor off...the "coupler" is three pieces that are made up of two white plastic pieces and a middle black rubber piece...(about $15) It's there and designed to fail first before you burn out or break the motor or transmission. The motor is held on with two Phillips head (star) screws and two clamps...you should have no problem taking it off, replacing the coupler and reattaching them all...
Hope this helps.
-PGB-
Posted on Dec 20, 2007
  • 87 Answers
Need new lid switch
Posted on Jun 17, 2007
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Our older top loading Whirlpool washer skips FILL
It sounds like you have a timer going bad.
Mar 06, 2010 | Washing Machines
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
Whirlpool Inglis washer super capacity, 8 cycles, 2 speeds. Bought in May 2008. Works well and washes well, but it is VERY loud and seems to be getting louder and now there is a faint rubbery smell when it...
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
Jun 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Water problem
Apr 01, 2009 | Washing Machines
Inglis washer LO-38002
any appliance parts store. it should be a stocked item.
Jan 10, 2008 | Kenmore 22422 Top Load Washer
Whirlpool LSQ8000 Top Load Washer Logo
330 people viewed this question
Sal De
Marvin
Marvin
jimorris77
