Question about Desa International Blower Glow Warm Wall Heater
Won't work when cold -- Glo-Warm 30K BTU Wall Mount Propane unit
I have a Glo-Warm 30K BTU wall mounted propane unit. Installed 3 years ago. Designed to cover approx 1000 sq feet, covers first floor of home which is 994 sq ft overall, approx 650 sq ft if I close of unused rooms to just heat living space in use.
Unit connected to less than 8 feet of iron gas pipe, last 1 foot of which passes through wall to exterior of house. Iron pipe then connects to approx 30" corrugated line, then regulator / fitting which connects to 100LB propane tank. I have a stryofoam cover over the tank connection / regulator that I fashioned out of a cover normally used for an outside water spigot in winter, the sides are cut out. (Reason: used to have rain / snow freeze onto regulator).
Iron line installed with a "trap" beneath the heater for debris / water, this is clear. Iron line "slopes" downhill slightly from heater as line passes through wall to exterior of house, then meets corrugated line which curves gently upwards to meet the tank (no kinks). Corrugated line does no appear to have water or debris in it.
Operational details are as follows:
-- unit worked flawlessly when first installed 3 winters ago
-- unit has manual pilot / piezo igniter and variable gas control
-- last winter, and now progressively moreso this winter, unit does not work when outside temp drops below approx 20 - 25 degrees F
-- if outside temp is above 20 - 25 degrees F it works absolutely flawlessly, strong clean blue flame, output as if brand new
-- unit usually has pilot, but pilot "shrinks" when you turn up the unit to "ON" , possibly due to the "draw" of feeding the main burner
-- when very cold, pilot will ignite for a few seconds, then burn out, must wait a while to try to reignite pilot, unit rarely works to fire burner afterwards (perhaps pilot runs on propane in line, then poor volume or pressure causes it to exhaust the propane in the line before it "backfills"?)
-- if I am using unit as the outside temp drops, flame height in the unit decreases with occasional "orange": (oxygen?) "spikes"
Should I:
-- replace the thermocouple
OR
-- replace the regulator
OR
-- perform other troubleshooting?
Thanks very kindly for any assistance or advice ... J V
    New Friend:
I have the same problem with mine....have you got it figured out yet?
Posted on Nov 29, 2013
1st panel on Vanguard 22,000 btu ventless propane wall unit has overshooting flame causing strong exhaust-like odor in house. Has black residue coming out of top vents. No fan on this unit.Help!
good thing that you turned it off as it is now not operating as designed and that makes gas dangerous
call an accredited gas fitter to properly diagnosed the problem and repair/ replace it
Jan 01, 2017 | Vanguard Heating & Cooling
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Internal 1/2 psi propane regulator is not passing gas thru so that heater wont light. Are there recalls? Where can I buy a replacement part? Heater is 2 years old, never lit.
What's the pressure to the heater? It should be a minimum of 11 to 13 water column inches. Also, make sure that your heater is in fact a propane fueled heater. Don't go by whats on the box it came in. Look at the manufacturer's tag(s) on the heater. It may be a Natural Gas unit instead of Propane unit. I've seen this happen before. In which case it won't work and can not be converted.
Feb 02, 2011 | Dyna-Glo D-E37 Wall Mounted Panel Heater
I had purchased this unit RMO-80LPT heater several years back, I never installed unitl this week. the sales en at the time told me it was gas/propane. Now seeing the -80LPT on the side is it propane...
The orifices for a propane heater are much smaller so you will not be able to get the natural gas to flow properly with the current orifices.
The both the natural gas and propane valve are 1/2 psi so the valve can be used but the regulator for propane is typically 8-11 inches on the wc table and the natural gas is typically 3 lbs on the wc.
You may be able to drill out the orifices in the burner and in the pilot ods and get the unit to work.
Oct 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
I have a 30k btu glo warm heater how do u switch from propane to gas
change the pilot n burner orffices. they r larger than propane gas orffices. good luck
Nov 23, 2009 | Heating & Cooling
How do i adjust the flame on ,my glo-warm propane heater?
if there is any adjustment it will be on the gas valve itself under the front of the unit....should have a little door that pulls down....you should see a knob that says "Higher....Lower" something like that....if the knob only says "ON , Off and Pilot" there is no adjustment
Oct 19, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
Desa International Blower Glow Warm Wall Heater Logo
274 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
