Question about Samsung UN-40EH5000 40 LED HDTV
Sound output not available for external speakers
Sound is good in the tv. It is just that when I connect with external speakers and use different sound options there is no sound on the external speakers.. tried al the various sound options on the tv. (Using the tools - Sound window - Amplifier, Movie, Music etc) Wanted to use external speaker while running movies via the USB port available in tv.. (Movies are available in external Hard Disk connected to the USB port).. External sound system currently put in place is Creative 5 : 1 When I use DVD player (ONIDA) and use its sound output to the external speaker it works fine... Not sure what needs to be done to sort this issue since on checking the web there does not seem to be any one with the same problem...
  • 304 Answers
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Posted on Jul 16, 2009
SOURCE: I have a Samsung UN55B7000 tv and a HT-BD3252
Make sure you turn on the surround sound located on your remote, should be second button from the bottom all the way over on the right.
Posted on Jan 06, 2010
  • 610 Answers
SOURCE: I have a Samsung LN-T1953H TV and the sound
It sounds like the main board has gone out. The only audio components are the main board, wiring and speakers. Since audio is missing from external speakers as well, that tells you that the main board is at fault. The cost of the board could be from $150.00 to almost $300.00 depending on the version # of your unit and dealer mark up. You can call 1-800-samsung for nearest service center.
Posted on Mar 18, 2010
  • 304 Answers
SOURCE: Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Posted on Apr 16, 2010
  • 8457 Answers
SOURCE: I have a Samsung LNT4053HX.
U have a small power surge somewhere.Disconnect all connections to the tv and unplug the tv and replug it back like about an hour later.Reconnected all connections.Go into the the tv Sound Setting to do a resetting of the sound setting back to the factory reset.The tv sound should work find now.If still have the same problems,then the main tv Tuner signal board it is shorted and have intermitten dying parts on the tv Tuner signal board.Only choice now is tries buy a refurbish tv Tuner signal board for the replcement.Tries websites like Shopjimmy.com,Ebay.com to buy LCD tvs refurbishes pcb boards.
Posted on May 27, 2011
Can I connect a 3.5mm audio cable from my TV to this JVC RX705V receiver?
So if you're trying to amplify the sound coming out of your TV to an amplifier you need to connect the output on the back of your TV on the receiver to the end audio input on the back of your receiver you might need different types of connections on each end but as long as you take the output on the TV and input it into your receiver your receiver will amplify the sound another way you could do it is to go inside the TV and connect two wires off of each of the two wires of each speaker leaving the internal speakers connected and then plug them in to the audio inputs on your receiver also if you're using one of the audio outputs on TV make sure you go into the menu and tell it you're using external speakers Good Luck Chuck
Mar 28, 2018 | JVC Audio Players & Recorders
Distorted sound
It is very possible that a speaker is bad. If you have the connections, try connecting external speakers to the TV to see if it still has the distortion. If so, then the audio output on the TV is bad.
Jan 12, 2014 | Televison & Video
I have a sony bravia KDL-32L4000 LCD TV and the sound has gone
For anything you plug in or just certain things? Before the sound stopped, did you change the sound output to something different? Do you have external speakers plugged in?
If the built-in speakers on the tv are not working, plug the television into a set of external speakers, select the output in the menu accordingly and test them. If they work, might be the speakers are blown or the menu configuration is wrong.
Always check the simplest things first, then work your way up to the harder/more expensive issues.
Rule out speakers, speaker board, connectors, external speakers, components attached to television, etc.
Mar 07, 2013 | Televison & Video
Kdl-32v4000 sound
Check the speaker first. Check if there is any sound output comes from the audio out terminals at the back of the TV, by connecting them to any external audio out devices; such as an amplifier or so. If there is audio output comes from the external source such connected, and no audio output from the TV; since the speakers are good, the fault is with the audio output section circuit inside the TV. If there is no audio output from the external sources too, the fault is with the audio processing section circuit at the main board. If this is the case, main board is faulty, and should be replaced.
Aug 07, 2012 | Sony Bravia KDL-32V4000 32 in. LCD TV
Good picture no sound
Hello
Check the speakers first. Get this set connected to an external audio amplifier device, such ans an amplifier or so, with its audio out connections at the back of the TV with audio in connections on the back of the amp, and listen whether you can see sound from the external amp. If you can hear sound from the external amp, and not with the internal speakers of your tv, either the speakers may have damaged or it audio output IC had got damaged. if so you have to replace the IC or should replace the audio card o your tV, if the IC is not available at local electronic spare part market.
If you can't hear any audio by external amp, as it has been connected as stated earlier, the mother board [main board] of your tv has the trouble. There is no repair to this digital board, and it should be replaced as card basis. OK.
Feb 08, 2012 | Vizio 42 in. LCD TV
I have a 29" Philips TV model 29PT4824/94R. The
To make sure that the external speaker is good or deffective try to use others speaker.If the other speaker work it means that your speaker is deffective and if the other speaker not work it means that the problem is the sound output amplifier or driver of the TV.You need to check the inner part othe TV.The board of the TV inside at the sound section, just fallow the speaker wire to the board,that is the sound section.Check if theres a loose connection.
Jul 16, 2011 | Philips Televison & Video
Can't get sound to come from speakers with tv only the radio
You didn't give the brand and model of your TV, and I can't try to find a manual and see what kind of AV connections it has available. So here's some general information.
Many TV sets only have input jacks for external sources like DVD players or cable boxes. When you select an external source, or use the set's internal tuner for TV programming, the video and audio play through the TV. The trouble is that if the set has no audio output jacks, there's no way to get a sound signal out. The TV accepts only inputs
When the TV is part of a home theater system, most people use it just as a video monitor. All AV sources connect to the receiver, and audio is sent from there to the speakers. A video output from the receiver goes to the TV so you can see the picture, and the TV's speakers aren't used. If you have a cable box, FiOS set-top box or satellite receiver for your TV channels, they connect to the receiver too, since they're just another external source.
This doesn't work if you rely on the TV's internal tuner for TV channels, though. This might be the case, for instance, if you have a cable system where a converter box isn't required and your cable connects right to the TV. When you're watching regular TV, then, the sound comes through the set's internal speakers. If there's no audio output available on your TV, that's your only option.
As I said earlier, many TV's have only audio inputs. But some have audio output jacks as well, so the sound has a way out. If yours does, you can connect them to one of the inputs on the home theater receiver. Then when you select that input you'll get the TV sound through the speakers connected to the receiver. Depending on the design of the TV, you may need to leave the TV volume turned up. Some sets have outputs that are follow the TV's volume setting. On others, the output is an independent fixed level. Then you can turn the TV volume down and use just the receiver's speakers if you want.
Check the connections available on your TV and look for a set of "audio out" jacks. Your TV's owner's manual should have a section explaining how to connect it in different ways. If you need a copy, most manufacturers have manuals for download on their website.
Good luck with your sound, and thanks for using Fixya!
Jun 17, 2011 | RCA Audio Players & Recorders
The speakers are not working. if i turn up the volume, I can hear static noise, but do not get any sound. tv speakers are on. I played around with the audio settinds and all the different hdmi ports,...
Hello
There are two possibilites for this fault. The first one is, damaged speaker voice coil and the second one is damaged audio output IC. To confirm it you have to open your TV. Speakers can be checked without removing them from the cabin fittings. Check them with the helap of a multimeter; set in OHms range. You can alos check it with a standard torch cell also. Connect the two terminals of the torch cell to the two terminals of the speaker [intermittantly, not constantly]; will produce a 'thumb' sound; if the speaker is good.
Connect the 'audio out socket' of the tv, with any other audio equipment, and listen whether there is sound form the external audio equipment, like amplifier or so. If there is sound from the external audio equipment, and no sound from the internal speaker of the TV, and the speaker is good, surely the 'audio output IC' of the TV is damged and should be replaced. OK.
May 13, 2011 | Vizio M550NV 55 in LCD HDTV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
External speaker hook-up possibility
Yes, its absolutely possible. You can connect external speakers from analog output of TV. Even you can use AV receivers available in the market which can be used to amplify OR process the tv sound with latest digital processing techniques, it would be very much pleasant than the sound from tv.
--Sandy
May 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung UN-40EH5000 40 LED HDTV Logo
51 people viewed this question
Jerry Greenberg
Jerry Greenberg
