Question about Home
Whripool covers I have an older whirlpool tub and the covers to the jet covers need to be replaced, the model is haven #4239. will the new covers that you have fit? the only other number that I can find on it is perspex made in sept 12 1986.
  • Anonymous Mar 28, 2014
    The lumbar jet impeller broke need new one with cover
  • 125 Answers
The likely hood of finding jet trim for a tub made that long ago is very remote. If you can email us pictures of what you have perhaps we can match them up for you. send photos to: sales@uspartscenter.com
US Parts Center
Posted on Feb 24, 2009
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Nov 16, 2015 | Whirlpool Home
Aker swrilbath tub want change jet colors
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Apr 06, 2013 | Whirlpool Royal A101A-R Bath Tub
I want to replace the 5 jet covers and suction cover for my Spurlin whirlpool tub. Where can I get replacement parts?
Mar 09, 2013 | Home
Hate my jetted tub
Cover them with fiberglass cloth and tresin.
Oct 02, 2017 | Jacuzzi Home
How do you remove and clean, or where do you find replacement jet knobs for americh jetted tub?
their jets un-thread counter clockwise. you will need to contact Americh directly. they will be able to sell you new jet trim.
Feb 19, 2011 | Americh Madison 2 6036 Bath Tub
I need new trim parts to change from gold to nickle on a pearl jetted tub model 143391-1 trim rings handle light cover..ect.
go to http://www.uspartscenter.com/shopbybathmfg.aspx you should be able to find the parts for your tub there.
Dec 16, 2010 | Whirlpool Pearl Navarre 7242 True Bathtub...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
My lasco whirlpool tub leaks scum from the jets do they make covers to completely seal off the jets?
you need to use a cleaning solution to get the bacteria out of the plumbing lines. suggestions: Jet Cleaner
Oct 31, 2009 | Whirlpool Home
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
155 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
